BanditKing
- Joined
- Aug 4, 2005
- Messages
- 290
I'm finally getting around to setting my drive chain tension on my own (usually had a shop or friend do it as part of a tire change, etc.)
The manual says the slack should be set between 0.8" (20mm) to 1.2" (30mm).
I set it at 20mm, and it seemed really tight, but that is the spec the manual gives.
30mm seemed borderline loose.
What do you guys with Gen1's set your chain slack to?
