DownRightAftCheck
I've been slowly building a turbo kit over the winter and have hit a stumbling point. I have a few questions for those who are a little more experienced with these things.
The fueling system is giving me some issues. Ive purchased a walbro pump and need to know where to go from there. From what I understand the second generation doesn't need an fmu and is more well suited to a 1:1 fuel pressure regulator. Which regulator should I purchase, I'm having trouble finding this part. There's mention of a 3 bar sensor, do I need this or not? Can I use the stock rail or do I need to upgrade that as well. The most I ever really plan on boosting this thing to is 8 psi after I put a spacer in and stainless valves/springs.
Also if anyone has a rich starting map compatible with the woolich program I would appreciate it greatly.
