IG.
I posted in General, but din't get much of a reaction, so I am re-posting here, where it's probably more appropriate.
I've been thinking... Tell me where I am going wrong.
You take a 4-stroke engine, and make the following changes.
o Change crank and cam ratio to 1:1 instead of 2:1, so for every revolution of the crank, the cams also turn once. Cams profiles have to be changed (new cams of course).
o Intake air is pressurized (5 - 10 psi).
o FI maps have to be re-adjusted.
o Ignition times have to be adjusted.
Here is how it is "supposed" to work. Let's start from ignition at TDC, and go 360 deg till next ignition.
-30 - 0 deg: ignition (negative degree for advance)
100 deg: exhaust valve opens
140 deg: intake valve opens, compressed air purges exhaust gases
170 deg: exhaust valve closes
180 deg: intake valve closes
230 deg: fuel injected, compression continues
300 - 360 deg: next ignition
All degrees are to just illustrate the principle. Of course, extra cooling is a separate matter.
That would be a two stroke turbo (edit: my mistake - supercharged, not turbo). What do you think?
<!--EDIT|IG.
Reason for Edit: "spelling"|1069359444 -->
<!--EDIT|IG.
