Hello
Brother and me made speedboat, powered with two busa engine.
We have done some tests, but engine lacks real power. I figured out, that engines runs in neutral map so I added resistor to pink wire, for 4. gear.
Now engines are harder to start so I will make switch to pin 19 to the ground, when starting.
How could I be sure, that engines are in gear map?
What is pin 20. (neutral input, blue wire)?
And one more- I hawe one engine for US and one for EU.
On US there in so wire from pin 19?? (I will make grounding just for one engine).
Here is lin from test. RPM are only half of real (I must install frequency doubler for rpm meter).
Thanks in advance,
Robert
Thanks in advance,
Robert
