tcat
I have a o2 Black/Blue Busa that is probably going to need a battery replacement. The battery is fine, it holds a charge and spins motor easily. This Busa has never had a kickback problem from the starter motor but I have been told if you attempt to start it with a weak battery or if the throttle is open there could be a kickback issue.Being the bike is heading into season 4 I will err on the side of chicken and replace the battery whether it needs it or not. Now that my long-winded story is over what Battery is a good replacement? I know Yuasa makes a YTZ14S that fits and has 235CCA which is an improvement over the stock battery output. Any Other Suggestions? Thank You TCAT
