Well the battery is finally dead in the Busa lasted 4 years. I was wondering if i could fill the cells back up with the acid. and just recharge it. I used to work at the local suzuki dealer so i have acess to things most people dont.
that could work but usually when a battery dies its because the cells give up not the acid.
sounds like you already know that you need a new battery then
if i buy tonight when will it be here
$65 bucks. Send out tomorrow.
Motorcycle Batteries | MotoBatt - Gel Sealed, Ready to Use | Pashnit Moto
New battery is the way to go. You should also invest in a Battery Minder for $40. This device can desulphate your dead battery and often rescue all but the deadest of the dead.
Amazon.com: BatteryMINDer Charger/Maintainer/Desulfator - 1.3 Amp, 12 Volt, Model# 12117: Automotive
it will pay for itself with the first battery you rescue. It's good for the environment too!
