In my search to get info for sprocket swaps, extended swing arms, chain lengths, and speed in gears i spent way to much time trying to find everything i needed. So i compiled everything i found into this thread to make things easier for other people and reduce repeated threads. All the information is here, just not all in the same location. There are Calculators EVERYWHERE but they do not fill themselves out. You will need this information.
Chain Length
Gen 1 Stock Chain 530 pitch 112 links with a 17 Tooth Front and 40 Tooth Rear
Gen 2 Stock Chain 530 pitch 114 links with a 18 Tooth Front and 43 Tooth Rear
Stock chain within stretch limits can handle a maximum sprocket swap of
-1/+3
0/+4
+1/+5
Swingarm Extensions
Extended Add
0-3"______+10 Links
3-6" _____+20 Links
6-9" _____+30 Links
9-12" ____+40 Links
12-15" ___+40 Links or Add an addition 10 or +50 links for a 630 Chain
2 inches over add 6 links
4 inches over add 12 links
6 inches over add 20 links
8 inches over add 26 links
9 inches over add 28 links
10 inches over add 32 links
12 inches over add 38 links
Sprocket Ratio
Gear Front/Rear Sprocket Combinations
Sprocket ratio chart
10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
28 2.80 2.55 2.33 2.15 2.00 1.87 1.75 1.65 1.56 1.47 1.40 1.33 1.27 1.22 1.17
29 2.90 2.64 2.42 2.23 2.07 1.93 1.81 1.71 1.61 1.53 1.45 1.38 1.32 1.26 1.21
30 3.00 2.73 2.50 2.31 2.14 2.00 1.88 1.76 1.67 1.58 1.50 1.43 1.36 1.30 1.25
31 3.10 2.82 2.58 2.38 2.21 2.07 1.94 1.82 1.72 1.63 1.55 1.48 1.41 1.35 1.29
32 3.20 2.91 2.67 2.46 2.29 2.13 2.00 1.88 1.78 1.68 1.60 1.52 1.45 1.39 1.33
33 3.30 3.00 2.75 2.54 2.36 2.20 2.06 1.94 1.83 1.74 1.65 1.57 1.50 1.43 1.38
34 3.40 3.09 2.83 2.62 2.43 2.27 2.13 2.00 1.89 1.79 1.70 1.62 1.55 1.48 1.42
35 3.50 3.18 2.92 2.69 2.50 2.33 2.19 2.06 1.94 1.84 1.75 1.67 1.59 1.52 1.46
36 3.60 3.27 3.00 2.77 2.57 2.40 2.25 2.12 2.00 1.89 1.80 1.71 1.64 1.57 1.50
37 3.70 3.36 3.08 2.85 2.64 2.47 2.31 2.18 2.06 1.95 1.85 1.76 1.68 1.61 1.54
38 3.80 3.45 3.17 2.92 2.71 2.53 2.38 2.24 2.11 2.00 1.90 1.81 1.73 1.65 1.58
39 3.90 3.55 3.25 3.00 2.79 2.60 2.44 2.29 2.17 2.05 1.95 1.86 1.77 1.70 1.63
40 4.00 3.64 3.33 3.08 2.86 2.67 2.50 2.35 2.22 2.11 2.00 1.90 1.82 1.74 1.67
41 4.10 3.73 3.42 3.15 2.93 2.73 2.56 2.41 2.28 2.16 2.05 1.95 1.86 1.78 1.71
42 4.20 3.82 3.50 3.23 3.00 2.80 2.63 2.47 2.33 2.21 2.10 2.00 1.91 1.83 1.75
43 4.30 3.91 3.58 3.31 3.07 2.87 2.69 2.53 2.39 2.26 2.15 2.05 1.95 1.87 1.79
44 4.40 4.00 3.67 3.38 3.14 2.93 2.75 2.59 2.44 2.32 2.20 2.10 2.00 1.91 1.83
45 4.50 4.09 3.75 3.46 3.21 3.00 2.81 2.65 2.50 2.37 2.25 2.14 2.05 1.96 1.88
46 4.60 4.18 3.83 3.54 3.29 3.07 2.88 2.71 2.56 2.42 2.30 2.19 2.09 2.00 1.92
47 4.70 4.27 3.92 3.62 3.36 3.13 2.94 2.76 2.61 2.47 2.35 2.24 2.14 2.04 1.96
48 4.80 4.36 4.00 3.69 3.43 3.20 3.00 2.82 2.67 2.53 2.40 2.29 2.18 2.09 2.00
49 4.90 4.45 4.08 3.77 3.50 3.27 3.06 2.88 2.72 2.58 2.45 2.33 2.23 2.13 2.04
50 5.00 4.55 4.17 3.85 3.57 3.33 3.13 2.94 2.78 2.63 2.50 2.38 2.27 2.17 2.08
51 5.10 4.64 4.25 3.92 3.64 3.40 3.19 3.00 2.83 2.68 2.55 2.43 2.32 2.22 2.13
52 5.20 4.73 4.33 4.00 3.71 3.47 3.25 3.06 2.89 2.74 2.60 2.48 2.36 2.26 2.17
When using Sprocket Caculators use these Gear Ratios For stock or reference the chart above for sprocket swaps.
Primary Ratio 1.596 For both Gen 1 and Gen 2
Sprocket Ratio is 2.353 For Gen 1, and 2.394 for Gen 2
Gear 1 - 2.615
Gear 2 - 1.937
Gear 3 - 1.526
Gear 4 - 1.136
Gear 5 - 1.136
Gear 6 - 1.043
Stock Tire Is 76.75 inchs or 1953.4mm in diameter if it is Bridgestone Battlax BT-015 190/50R17
Chain Pitch 15.8752mm
Rev Limit
10,800 Gen 1
11,300 Gen 2
Gearing Commander: Motorcycle Gear Ratio Calculator for Sprockets RPM Speed Chain (all around calculator)
Motorcycle gear/rpm/speed calculator (Motorcycle gear/rpm/speed calculator)
SPROCKET SPECIALISTS-Sprockets for all makes of bikes. (Chain Length and Gearing Calculator)
http://www.dropbears.com/u/utilities/images/Gearing_V12.zip (Easy program calculate thespeed in any gear at any given rpm)
Chain Length
-1/+3
0/+4
+1/+5
Swingarm Extensions
Extended Add
0-3"______+10 Links
3-6" _____+20 Links
6-9" _____+30 Links
9-12" ____+40 Links
Sprocket Ratio
Gear 1 - 2.615
Gear 2 - 1.937
Gear 3 - 1.526
Gear 4 - 1.136
Gear 5 - 1.136
Gear 6 - 1.043
Rev Limit
10,800 Gen 1
11,300 Gen 2
