Advice needed for nitrous on Gen1 engine in a light small car.
Discussion in 'Nitrous' started by Keppni, Jul 12, 2015.
  1. Keppni
    Keppni Registered
    Contests won:
    Name:
    Sigurjon Johannsson
    I have installed Gen1 engine in a 1500 lbs car, and its works great!
    I like to take it to the 1/4 mile drag-race, and now I want to add some few hp to it, what else ;)?
    I have done some searching here but as my project is "different", I am hoping you guys with your knowledge can help me out.
    Can you give me some good advice's on what Nitrous I should go for and not the least, can anyone help me out with a good suitable Map? Could 50 hp with the right map be okay?
    The engine is stock with PC5, Autotune module, custom build exhaust (flows very well), High volume fuel pump (Walbro 255), TRE installed, stiffer springs in the clutch and always running 98 oct fuel. I am going to use a Foam air filter (55 mm high, pls see the picture here: Competition Filters | Pipercross Performance Air Filters
    Also where should I install the nozzles as I am not using the standard Hayabusa Airbox? Can I spray inside the Foam air filter?
    Thanks
  2. Gixx1300R
    Gixx1300R Registered
    Contests won:
    Post pis of your setup
  3. N2OGoGo
    N2OGoGo Registered
    Contests won:
    Name:
    Mike Golightly
  4. GNBRETT
    GNBRETT Registered
    Contests won:
    maybe u shud sign up to be a Sponsor.
  5. N2OGoGo
    N2OGoGo Registered
    Contests won:
    Name:
    Mike Golightly
    Just showing the guy how nozzles should be installed in a cylinder head, wanted him to know who makes the stuff I use.
Share This Page
