Valingt
so i got this bike for cheap and i have been working on getting it all back to 100. i put a new fuel pump in and that helped some with this issue but still at 5500 rpm or so it just falls flat. i read somewhere that it could be timing but i was going to see if there was any other options or if that was most likely it.
the other thing is if it is timing how do i fix it. im not new to working on stuff just new to working on bikes. is there a window i can open to see if the timing is off? is there a way to turn the motor over without the starter and without draining the oil?
if its not timing what should i look at next after fuel pump. also its putting out 2 codes. c24 and c27. maybe that will tell yall the problem all together.
thanks in advance
Big Ben.
thanks in advance
Big Ben.
