2003 Hayabusa wont start HELP!!!
Discussion in 'General Bike Related Topics' started by lilcomp1977, Nov 14, 2008.
  1. lilcomp1977
    lilcomp1977 Registered
    Contests won:
    I just purchased my first busa... I rode it yesterday..Started it this morning.
    and turned it off before it could warm up.. Now it wont start.. I ran the battery down so I jumped it and it came up with a f1 code.. I did the Ghetto dealer switch and came up with code c-11... PLEASE help a newbie.!!!!!!
    Thanks,
    Matt
  2. Wag
    Wag Evil Demon Busa Rider Donating Member Registered
    Contests won:
    Name:
    Wag
    Does it crank or try to crank when you press the button? Does the light dim?
    A tad more detailed info would help us help you.
    I have an '03 too but anyone with a Gen 1 can help ya.
    --Wag--
  3. 99'busa
    99'busa Donating Member Registered
    Contests won:
    Name:
    chris
    im with wag. here. more details. dont know what that code is without the book.
  4. cerebusa
    cerebusa Registered
    Contests won:
    Name:
    mike walters
    The shop manual is on here some where, download that and you can look up the codes, its been a lifesaver for me over the years. I keep mine on a disc and on the desktop. It is the bible, so it is written, so shall it be done...
  5. tjdobb
    tjdobb Donating Member Registered
    Contests won:
    Name:
    Tom Dobberthein
    C-11 The manual says to check the camshaft position sensor or circuit malfunction.
  6. shawnski
    shawnski Donating Member Registered
    Contests won:
    Name:
    shawn r
    are you holding the clutch when you crank, did you try it with kickstand up or down sitting on the bike? DOES IT CRANK ????
    try to have someone push the bike while you sit on it and release the clutch in second gear see that would start it up.
  7. twotonevert
    twotonevert Member of P.E.A. Moderator Donating Member Registered
    Contests won:
    Name:
    James Wilson
    Welcome to the board. If it ran fine yesterday, disconnect the battery cable and leave it off for a few minutes. Reconnect and see if you have same problem.
  8. lilcomp1977
    Contests won:
    The bike turns over fine there is no code until I try too jump it. Then the code pops up. I here the fuel pump running. I pulled the plugs and cleaned them. Im going to take the battery out and charge it now.
    Thanks for all the response already.
  9. mike1180
    mike1180 Banned
    Contests won:
    Name:
    Mike A
    :welcome:
    To my knowlegde the injectors won't work unless the battery is fully charged.
    I would take the time and charge it up fully, as you did drain it down to nothing.
    I can't see cam sensors going bad just because you ran the battery down.
    JMO
  10. J.Busa
    J.Busa Registered
    Contests won:
    Name:
    JOEL
    What are you jumpstarting it off of? Not a running vehicle or a jumpbox I hope.
  11. TruWrecks
    TruWrecks Banned
    Contests won:
    Name:
    Doug Truex
    The bike won't fire until it has 12.4-12.6 VDC while cranking. How are you jump starting it? If you are using another vehicle I hope it isn't running. A running car or truck can spike up to 14.8 VDC when it sees the additional load from the bike's battery. That is too much voltage for the ECU of the bike. Leave the bike on a charger or connected to the battery of a car and lit it charge for about 30 minutes. Then you should be able to start it back up.
    If the C11 code comes on you will want to disconnect the battery ground, and turn the key to run. Leave it like that for a few minutes. Turn the key off and reconnect the battery ground. Try to start it again. If you still get C11 you may have a loose connection somewhere.
    The clitch lever will need to be pulled, and the side stand will need to be up or trans in neutral or the starter won't get power.
    NickSlick has a download link for the service manual that was posted a while ago. I'll see if I can find it.
  12. TruWrecks
    TruWrecks Banned
    Contests won:
    Name:
    Doug Truex
  13. TIMMYDUCK
    TIMMYDUCK Head Woodchuck Donating Member Registered
    Contests won:
    Name:
    Timmyduck
    When you shut it down did you lock the steering stem ?
    If you did you might have gone to far with the key and left your parking light on, thus draining your battery.:laugh:
  14. lilcomp1977
    Contests won:
    Ok I found my problem with the cam position sensor.(it wasnt snapped all the way in) I snapped it in and tryed to start it. It fired probably five times. And wouldnt start. Now it wont fire. It still turns over fine and I can smell the gas and hear the fuel pump. Could the plugs be fouled out? The bike has 5200 mi.
    Can you use starting fluid? I dont want to try that until i have to.
  15. Wag
    Contests won:
    Name:
    Wag
    I don't like starter fluid on an injected bike. Don't know why, it just makes me a bit uncomfortable for some reason.
    I think you can foul the plugs. I suppose you could pull 'em and let 'em air out a bit.
    --Wag--
  16. Big Red
    Big Red Donating Member Registered
    Contests won:
    Sounds like you fowled the plugs
  17. Supergank1
    Supergank1 Registered
    Contests won:
    Name:
    Eric A
    change the plugs and fully charge the battery and it should be good..now that u plugged the cam sensor back in. :welcome:
  18. Poppy
    Poppy Donating Member Registered
    Contests won:
    Name:
    George
    Kill switch position is.........?:poke:
  19. Bertactive
    Bertactive Registered
    Contests won:
    curious, did u figure out what was the fix?
  20. GIXERHP
    GIXERHP ok, ok...just a wee bit Irish... Donating Member Registered
    Contests won:
    Name:
    JOHN HAYES
    Ahem,, 3 year old post!
Share This Page
