Jake Boucher
2 days ago my bike was knocked over in a parking lot, frame slider and bar ends saved her for the most part. Up until then she has been running great. I bypassed the high pressure filter in the tank and used an inline filter, and that brought my midrange and top end back to life. She was only on her side for 30 seconds or less, I ran my 160 pounds over their and lifted her fat self back upright. She runs great until I've been riding her for a while and she's warm. At first she was loose power and be a bit jerky, now she's smooth but gutless. I checked the tip over switch, no problems there. Pulled the plugs, and they looked lean if anything. No oil where it shouldn't be. I'm just confused because it's heat related. I considered vapor lock, but it only just started doing it and I did the filter bypass weeks ago. I'm going to tighten my throttle body clamps, and double check my vacuum lines right now. I'm having a feeling that problems after the tip over are just a coincidence. Anything I'm overlooking? Tank vent lines are good too.
