Timing depends on fuel, charge cooling, howmuch boost, and what you are doing with it.
If you have a fairly conventional system, and you are only drag racing and using a fuel such as VP C16, ~28-30 degrees timing should be good for up to about 30psi boost with lowered compression. It really depends on what the complete setup is.
