Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 21 to 40 of 46
  1. #21
    Top Gun 2Wheels2Live's Avatar
    Join Date
    May 2008
    Posts
    1,077
    Default Re: Supercharged Hayabusa 08
    Too bad it has to stick out so much, and hang down so low. I wouldn't want my filter that close to the ground and unprotected.
  2. #22
    New Recruit Marcus's Avatar
    Join Date
    Jun 2009
    Location
    Denmark
    Posts
    51
    4 Cylinder
    2 Whells
    **And**
    1 Blower
  3. #23
    New Recruit
    Join Date
    Apr 2005
    Location
    UK
    Posts
    66
    The Big CC Supercharger system uses a US made Procharger supercharger unit instead of the Rotrex. Boost pressure for boost pressure we have found it to be more rewarding. It is gear driven rather than oil driven which makes it whine like a charger. If that is a bad thing i dont know but most people actually like the sound.
    It uses a turn ratio of 4.7 to 1 rather than 10 to 1 & so uses a much bigger impeller to compensate hence the bigger body but the plus side is a cooler inlet charge to the plenum hence better efficiency.
    There are several other differences in the way of tensioning with a 3rd wheel & larger bore up pipe & plenum & much wider belt etc to give more grip on the pulleys. That though you can see in the pictures.
    Below is a comparison at 10 psi between the 2 chargers... Rotrex & Procharger. The Procharger was 30bhp more efficient. Air fuel & engine specs were the same. (red graph also had cams fitted)
    Filter wise its actually pretty difficult to ground out but its also possible to re route the flter elsewhere if you dont like it low slung. What we did not want to do was compromise the inlet diameter from the charger to the filter hence the work effort in the tight radius's
    Regards pulleys at the side of the engine, you can always try putting them to the front
  4. #24
    Seasoned Beef
    dadofthree's Avatar
    Join Date
    Sep 2006
    Location
    Barnwell, SC
    Posts
    66,690
    Not bad. B-King on steroids
  5. #25
    Call me Liberace!
    ogre's Avatar
    Join Date
    May 2009
    Location
    The Northwest
    Posts
    5,337
    vid with the whine please.
    Thankful for his Friends...
    2006 Raiment White Hayabusa
    Lumen Junkie in Residence
    Why retros are safer than HID kits
  6. #26
    Rookie mrjoeys50's Avatar
    Join Date
    Apr 2009
    Location
    Mittleburg Germany
    Posts
    192
    yeah i bet that whine sounds great... I have a procharger on my Mustang and that sound is unmistakable
    "Hey, watch this"
  7. #27
    Join Date
    Apr 2009
    Location
    Mittleburg Germany
    Posts
    192
    not the procharger but still sounds good
    YouTube - Hayabusa Bastard SUPERCHARGED!!
    "Hey, watch this"
  8. #28
    Seasoned Beef
    dadofthree's Avatar
    Join Date
    Sep 2006
    Location
    Barnwell, SC
    Posts
    66,690
    Robert
  9. #29
    Seasoned Beef
    dadofthree's Avatar
    Join Date
    Sep 2006
    Location
    Barnwell, SC
    Posts
    66,690
    Can't find the guy or his thread(s) but he joined up last month and gave some great shots of the bike.
    Robert
  10. #30
    New Recruit
    Join Date
    Nov 2009
    Posts
    94
    In regards to the bigCC procharger; how much boost is that? And if I were to take am '08, space it and drop SS valves and stiff springs in, how much more psi could I run?
    1ST GEN-10R 234hp/100ft.lb@7psi, GT2871RS, cometic gasket, tial bov/ex wastegate, BEGI FMU, WALBRO fuel pump,falicon clutch basket,race pak clutch,200/50 pilot,yana-shiki levers, WEGO III,PC3,GPR damper,cbr cals/Galfer SS brake lines,gp shift,1/5 throttle, 2NDARIES REMOVED
  11. #31
    Hayabusa Immortal
    Mr Brown's Avatar
    Join Date
    Mar 2005
    Location
    618
    Posts
    6,224
    I have a brother in the UK who lives close to Big CC. He is taking his Gixxer 7/11 to them to get it dyno'd. If he or I can be of any assistance, just holla.....
    Ignorance can be educated, but ya can't fix stupid!
    00 Black
    618 Performance Syndicate
  12. #32
    Hayabusa Legend
    Big Red's Avatar
    Join Date
    Apr 2005
    Location
    Irving Texas
    Posts
    2,191
    Images
    25
    There is nothing like a belt driven supercharged engine for instant throttle response. What a thrill!
    No one has ever convinced me that this is not paradice.
  13. #33
    Join Date
    Jun 2009
    Location
    Denmark
    Posts
    51
    Quote Originally Posted by Cookie View Post
    One or two guys I have known over the years with them have reportedly been extremely happy with installation and total performance. I have lost track of who those were. Most were TTS Suzuki Hayabusa Supercharger . Is that the kit you would be installing? It sticks out a little, you have to cut the fairing,, but so do you on a turbo,, so what, right?
    I Thing i know this Bike
    My Haya Compressor Dragbike build from stock
    4 Cylinder
    2 Whells
    **And**
    1 Blower
  14. #34
    Supercharged's Avatar
    Join Date
    Nov 2007
    Location
    New Jersey
    Posts
    37
    8.24 @ 172 all day for over 4 years, as you see it, even with the wheel in the air.
    Attached Images Attached Images
  15. #35
    Seasoned Beef
    dadofthree's Avatar
    Join Date
    Sep 2006
    Location
    Barnwell, SC
    Posts
    66,690
    Great looking ride
    Robert
  16. #36
    New Recruit
    Join Date
    Nov 2009
    Posts
    94
    Quote Originally Posted by Supercharged View Post
    what work was done to your bike? how much powerand #'s?
  17. #37
    Hayabusa Immortal
    Commuta_Busa's Avatar
    Join Date
    Mar 2003
    Location
    Carteret, NJ
    Posts
    7,671
    Images
    107
    I saw you run at Atco
    2009 Super Streetbike's Top Speed Challenge Winner
    Unlimited naturally aspirated class
  18. #38
    Professional Pilot
    Join Date
    Jun 2007
    Posts
    804
    nice....I imagine the supercharger is quite easy to learn to go fast on compared to a turbo
  19. #39
    New Recruit
    Join Date
    Nov 2009
    Posts
    94
    i just got this months issue of super streetbike in the mail, on page 84 theres a naked 08 busa sporting a big cc charger with a built motor and its only putting down 281hp!? for the money this guy put into his motor i.e. low compression 1365cc motor with all the cams and goodies to go with it, hed have so much more power if he just went with big cc's stage II turbo kit what gives
  20. #40
    Join Date
    Nov 2007
    Location
    New Jersey
    Posts
    37
    I have to speak out for all superchargers, They will never make the power a turbo make! Given the same parameters. They have what I call usable power. Which makes them more ride-able
    Look at the times I can do in the 1/4 mile, compare them with a turbo and I bet they are making more hp to do the same e.t.
    As far as numbers, it makes 310-320 ish to the rear wheel when a lock up clutch was installed. No intercooler or water injection. It rarely sees a dyno because we tune by data logging.
    We have an intake cam on the ex, which is being replaced with a stock cam now, we believe the 2 intakes hurt the power. drop in je turbo pistons, hd valve springs, good rods, bigger injectors and fuel pump.
    They are very easy to ride, nothing different from a regular bike except a lot more power! This one is a little intimidating but the street version is smooth, and fast. This one came in with an already 2 mil bore, all we did was put in turbo pistons and he opted for turbo cams, nothing else and it made 256 to the rear wheel.
    Thanks!
Similar Threads
  1. Supercharged B-king!
    By bigoltool in forum General Bike Related Topics
    Last Post: 11-19-2008, 05:17 PM
  2. Supercharged vs turbocharged.
    By mikev7 in forum Super Chargers
    Last Post: 11-26-2007, 04:10 AM
  3. Supercharged M3
    By vman1300 in forum Random Thoughts
    Last Post: 11-22-2006, 10:15 AM
  4. Supercharged Hayabusa
    By BBlue Silver in forum Turbo
    Last Post: 01-21-2005, 06:07 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
