<div> (BlueHaya @ May 27 2007,17:37)</div><div id="QUOTEHEAD">QUOTE</div><div id="QUOTE">Great write up. * It looks like a totaly different bike in the end.</div> It was,,think last pic was r2b's bike,,,lol Bike #1 was in need of some meengreen & garden hose. ______________________________________
02 Black & Blue Air box Mod,Blue gauges 220 PC IIIr,Blue LED's.SS Lines Lowered ,HiD 6k,Water Weter Gorilla Alarm,Pazzos M4 full Exhaust, Speedo Healer GPS "Tom Tom" Muzzy fan,16-42 RoadLoK� Arachnid�S2, Corbin,Front & Rear,Clear Clutch Cover Sirius Satellite Radio,Altoid Amp JohnnyCheeseMan Tune 1397 comming soon Â*"Never be afraid to try something new. Remember, professionals built the Titanic." And amatuers built the Ark |
Great write up, and good pics - If I can make a couple of suggestions - as an alternate procedure: Do not remove the nut and bolt from the tq arm, you can simply loosen it; doing so will allow you to swing the caliper down, away from the rotor, once you have removed the bolts from the caliper and caliper hanger/bracket/mount/spacer. As stated only retract the axle far enough to remove the bracket, then replace with the RoadLoK; doing so, you will usually not have to pry the pistons on the rear caliper, it will slide back on the rotor. All other procedures are the same as listed. Again, just an alternate procedure; works especially well when installing the RoadLoK alone. ______________________________________
GSXcite - Crew Chief; Omslaw - Test Pilot/electrical advisor; GSXtacy - mechanic; Semi - mechanic Grandpa Busa - structures; Zuk Racer - mechanic G Joker - Parts expediter; thepusherc.g. - paint/body and mechanical adjustments; Nitrous Junkie - Ergos; Captain and Boaz - athletic supporters All I remember is: ground, sky, ground, sky, ground, sky, ground, sky, emergency room! |
| Thread Tools | |
| Display Modes | |
