You need to have your speed up, so when the back wheel comes up you travel forward and not over. When you apply the brake you bounce with your weight forward to help the back wheel come up ______________________________________ http://www.youtube.com/watch?v=oAJkggt31qE 06LE Roadlok,Frame sliders, Muzzy,PC3,CBF mirrors 07 Chrom (rims, gauges,grips,levers brake&clutch cover, crash cage, tank pad,triple tree )Muzzy exhuast,roadlok, woodcraft ign with red slider, |
<div> (Cloud9 @ Sep. 22 2007,21:12)</div><div id="QUOTEHEAD">QUOTE</div><div id="QUOTE">I forsee an bike dropping incident in your future... ![]() If you can afford to drop the bike, I would try that on a lighter cheaper bike.</div> +1 ______________________________________ |
thanks for the tips... i just wanted to give it a shot (I was actually testing hard braking rather than anything else) and since I've seen it done I figured I'd give it a try. I suppose I was expecting it to be easier to at least get it off the ground by an inch or so. I'll probably leave it at that, now knowing the bike will stay planted pretty much no matter what! ______________________________________ |
"Seen it done," is not the same as doing it! Take the above advice, implied and explicit, and learn how to do it on some other, much less expensive bike. You can buy a small bike for as much money as you're going to spend if you rash up your Busa. --Wag-- ______________________________________
"Morality is doing what is right no matter what you are told. Religion is doing what you are told no matter what is right. " -- Unknown
Doing a stoppie on stock brakes is not easy, but with lines, pads, and rotors it's too easy. ______________________________________
04 Blue/Silver: Chrome RS-3's Power Commander 16/42 hump mod (inside and out) dampner mod K&N EBC pads & rotors screens Suzuki gel seat busa hand grips air box mod galfer front lines Throttlemeisters |
leave it to the pro's ______________________________________
mods yoshi 4into1 full ram air mod 2nd 3rd 4th and 6th remapped pc3 usb k&n air filter custom fairing grills custom skellington top yoke custom grab rail custom axal protectors custom oil filler cap custom levers custom torque brake arm white turn signals blue d/b screen wavey disk |
Don't really understand WANTING to endo,or wheelie for that matter on the 'Busa.It's tendency to not do those thing's is one of my likes about the bike. ______________________________________
black & grey 06 muzzy exhaust power commander K&N filter marble mod |
<div> (black06 @ Sep. 25 2007,14:24)</div><div id="QUOTEHEAD">QUOTE</div><div id="QUOTE">Don't really understand WANTING to endo,or wheelie for that matter on the 'Busa.It's tendency to not do those thing's is one of my likes about the bike. +1, That's one of the reasons I bought mine, if I wated to endo and wheelie I would have a GSXR 600 or 750 ______________________________________ |
Things to consider when trying to do a "stoppie" on the Busa. It is a heavy bike. since it is heavy the following issues are to be considered. 1) Harder to get the rear wheel in the air, and if and when you do, probably going to be harder to control. 2) The heavyness of the Busa is going to crush your stock forks (wont actually "crush" them. but it is going to put a lot of stress on them. 3) Due to the heavyness of the busa, if you are not able tto gently put the rear down gradually (which will be hard to do) you might start causing excessive stress on the frame which could cuase it to crack. Having your bike break in two some day due tto excessive stress while normal riding would not be a good thing Anyway, like others said I would recommend getting a smaller lighter bike to play with, stoppies and wheelies are fun but the busa just isnt built for that type of fun (in my opinion for what it is worth) ______________________________________
One of Satan's greatest deceptions is to convince the world he does not exist. "If we will not be governed by God, then we will be ruled by tyrants." --Wm. Penn www.biblegateway.com |
#1 priority for me when I bought the bike- BUY BETTER TIRES!! I bought Qualifiers, then put on EBC HH sintered pads, then stainless brake lines. THEN practiced low-speed braking, pulled about a 3-6 inch stoppie and called it good. Mostly it's the tire, get any one of the top three you've seen talked about on here and get it warm and it will pick up the rear before it slides. This will teach you how hard you can brake in an emergency before the rear comes off the ground. Get new rubber, it's easier in a straight line to deal with a light rear end than a locked front tire. ______________________________________
Shibumi- Effortless perfection. That describes the Hayabusa! 03 Black/Silver- Akasha Power Commander/BMC Race/TRE/Muzzys/Lowered/Galfer stainless lines/Pingels/Puig Double Bubble smoked/Shovel mod/Pazzo shorties/HID/CA clear taillight w/integrated LED signals/Clear front signals/Qualifiers |
Oh, here you go from WWJD's thread... ______________________________________
| Thread Tools | |
| Display Modes | |
