Smarter than a 5th grader??
BUSA_CHeMiST
Sorry if this is a repost, took me a couple minutes...DONT POST THE ANSWER! See if you can get it.
FOLLOW THE INSTRUCTIONS:
Detach spreadsheet and save to desktop then work word problem and open
spreadsheet and type your name on the list and save then send to people
you think can answer or cant...lol GOOD LUCK
This excel spreadsheet is password protected with the answer to the
following riddle:
Good luck with this and have fun! This is a 5th grade math problem.
If you can't stand word math problems, just delete now, because this one
is a bugger. If you can open the spreadsheet, you'll see it's a very
small list of people who have gotten the correct number.
This is not a trick question.
There are 7 girls in a bus
Each girl has 7 backpacks
In each backpack, there are 7 big cats
For every big cat there are 7 little cats
Question: How many legs are there in the bus?
The number of legs is the password to unlock the Excel sheet.
If you open it, add your name and send it on to see who else can unlock
it.
(See attached file: Smarter Than A 5th Grader.xls)
  • SmarterThanA5thGrader.zip
It works better if you zip it. PPPPPPPSSSSSSSTTTTTTT. Look inside
  • post_12_07410_SmarterThanA5thGrader.zip
That was cake!
Trying to open, save, edit, add my name, save... That was 100 times harder than the 5th grader problem....
nice list
  • post_12_08447_SmarterThanA5thGrader.zip
I got the answer. The riddle isn't hard. Like others have said, posting the excel sheet is the trick.
i got it but im not smart enough to put my name on the list
i was waiting for a trick about a bus driver. but one of the 7 girls could be the driver so i went with 7 human legs. and i was right.
I added two legs for the bus driver the first time, then got it on second try without bus driver.
