Watched an episode the other day that talked about how to stop the burn from eating Hot Peppers or Hot Sauce. You can't believe some of the things people suggested to cure the burn. Some examples submitted and tested
1. Milk
2. water (room temp or cold can't be sure)
3. Vodka
4. Wasabi sauce
5. Beer
6. Petroleum Jelly (Yep, they put a spoonful in there mouths)
SO what do you use to cure the burn?
This is an old trick I learned from a bartender almost twenty-years ago and it works!
Take ANY water based drink (I prefer tap water) your going to do this approx three or so times.
Rinse and spit three times, but here's the catch you MUST make the drink a little bit warmer each time you rinse and spit! The final time should be slightly cooler than a cup of hot chocolate..... There you have it THE ONLY cure I know that works! Now, the sad part is the first rinse even at room tempature may appear to be unbearably hot. But, I promise after spitting out the slimey substance from your mouth (gets that way I guess from the pepper oils)that by the third time no more burn!
Pepper lover here...
1. Milk
3. Vodka
4. Wasabi sauce
5. Beer
