I'm trying to make it flush as i can to the floor, since i will be hauling 4 bikes sometimes, then all the way down to our drag bike. I will keep you setup in mind though, thanksAnd yes, it has been painted and cleaned up since I took these pics.
I like the way you did yours, its flush with the floor and i could mount a few of those around the trailer and i can put the chocks where ever i want. The two bolts that mount the plate to the floor do they all the way through, they dont look like it. If not is it real strong, worries about it pulling out.Here is a closer shot. I used 1/4" plate 2" wide. Drilled two mounting holes with countersink, and two 3/8" center holes that I treaded with a tap. Marked the floor and used my router to fit flush with the floor. Although these are pictures of the mounts for the stands, I used the same ones to mount my chocks. If you can do the fabrication it will save you $$$ as the ones you can get from Baxley are $30 for two mounts.
I did not see this question untill now, but for those of you interested the mounting screws for the chock anchors do go all the way through the floor. Very strong, and flush with the floor.
