PING Canadian Mike and others..
runeight
why ask why
Finally received my parts from CM. Off to the powder coater they go but..
Which side of these pieces face you?
Don't want to get the wrong side powder coated. One piece marked with X. Easy to figue this out.
I'm thinking they will powder coat both sides anyway but want no suprises.
r8
The two (2) small pieces can be both sides. The large piece only one I would think.
r8
Professor, you interested in my clutch cover? Not sure if I'm going with it. Jury still out.
r8
outside cover you have showing is visible..
The 2 stands you have reversed.. the one with the 3 holes (one is off center line of stand) and the relief cutout go under the clutch slave.. (the second hole from the end without the relief and is bored off the centerline of the stand, is where the clutch pushrod goes through..
The reason I would NOT powder coat the stands or the backside of the big plate is just because powder coat is not "flat" and I would rather be double sure that the stands and cover are mated flat..
Oh and guessing you would know to use some AN washers if you powdercoat the thing and then put bolts down on it to keep from pulling the powder coat free of the piece.
