Results 1 to 12 of 12
  1. #1
    Formerly known as "Zuki"
    Join Date
    Jun 2005
    Location
    MN72Busa
    Posts
    3,147
    Default
    Ok, not sure if anyone has tried this, but ran into something intresting and thought I would share it with you.
    By adding 2.5 Oz of Acetone to 10 gallons of gasoline you can increase your fuel mileage by aprox 30 to 50%.
    Some people swear this is true, and have been experimenting with this for over a year with excellent results. Now, I have no clue what the long-term issues would be with doing this, but possibly premature seal wear?
    "By adding a small amount of acetone(nail polish remover) to your tank, you reduce the surface tension for the gasoline molecules and burn the fuel more efficently"
    Lets hear some member input on this...
    Linky to get you started on your reading adventure
  2. #2
    Turbo-Torch's Avatar
    Join Date
    Apr 2004
    Location
    Indiana
    Posts
    2,126
    Default
    Click and Clack had a column on that a month or two ago....ah here it is:
    Dear Tom and Ray:
    Last week my neighbor gave me an 11-page treatise on the benefits of putting a small amount of acetone in your gas tank: an increase of 25 percent to 35 percent in gas mileage with NO damage to the engine. The article tells how much acetone per number of gallons and gives the rationale for why it works. I am NOT knowledgeable in the workings of engines, nor do I have knowledge about fuels, so I can be snowed by people who may or may not know what they are talking about. I value your opinions. What do YOU think about this? -- Wil
    TOM: It's bo-o-o-o-gus, Wil. With four "o's." Don't put acetone in your gas tank.
    RAY: It does absolutely nothing to increase your gas mileage. We spoke to a fuel-systems engineer who works for one of the major oil companies. He said that because of all these rumors floating around on the Web, his company tested acetone in its own labs and found no increase in mileage. None. And he said the equipment is precise enough to detect anything over a 1 percent difference.
    TOM: But it's worse than useless -- it's also harmful. Acetone is the primary ingredient in nail-polish remover. And while it will burn and is a high-octane material, it's also a very powerful solvent. So while it's in your fuel system, it'll be eagerly dissolving all of your rubber components ... like gaskets and O-rings.
    RAY: In fact, some cars have a rubber hose in the fuel line that goes between the fuel-cap assembly and the tank. When you add your acetone, pouring 100 percent, undiluted rubber-eater right onto that tube, you'll be eating through it in no time.
    TOM: Here's our final reason not to use it: It dissolves paint. So if you slip and spill a little bit outside your fuel filler door, you'll have a nice, unpainted line running down to the bottom edge of your rear quarter panel. When we see you drive by, we'll know you didn't take our advice!
    George
    CX500 TURBO
    CX650 TURBO
    04 Blue/Silver Hayabusa
  3. #3
    Join Date
    Apr 2004
    Location
    Indiana
    Posts
    2,126
    Default
    Sounds like something Mythbusters should test out.
    George
    CX500 TURBO
    CX650 TURBO
  4. #4
    speachless
    Join Date
    Apr 2005
    Location
    Tampa Bay Area
    Posts
    3,396
    Default
    might as well put a little marvel mystery oil in your gas tank.
    Political Correctness:
    'Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.'
  5. #5
    On a Steel Horse I ride.
    BusaWizard's Avatar
    Join Date
    Dec 2005
    Location
    Kansas City, Mo.
    Posts
    11,451
    Default
    Is this the same thing as Tuolene I've heard this does the same thing?
    If you're not living close to the edge, then you're taking up too much space.
    Fast is easy. Quick is hard.
  6. #6
    Jr.Vice President Barron Butters
    BUTTER2BOY's Avatar
    Join Date
    Aug 2005
    Location
    BUSAMORE,M.D.
    Posts
    1,324
    Default
    Quote Originally Posted by [b
    Quote[/b] (Turbo-Torch @ Feb. 21 2006,01:39)]Sounds like something Mythbusters should test out.
    +1
    "If I Die Riding A Motorcycle, I Died Doing Something I Truly Enjoy And That I Live For.I Died Doing Something That
    Made Me More Of A Person,Not Less"
  7. #7
    Banned
    Join Date
    Aug 2005
    Location
    illinois
    Posts
    3,689
    Default
    my freind in town did it with his rc 51 and his van and he swears by it it works for him but i am leary bout puttin it in my bike
  8. #8
    D' Colonel
    DaCol.'s Avatar
    Join Date
    Nov 2005
    Location
    Oklahoma
    Posts
    7,814
    Default
    I bet that nail polish does wonders on the gaskets in the fuel system
  9. #9
    BlackBird rider, lol
    Join Date
    Oct 2005
    Location
    Joliet area,IL
    Posts
    3,239
    Default
    Quote[/b] (BusaWizard @ Feb. 21 2006,03:18)]Is this the same thing as Tuolene I've heard this does the same thing?
    I put Tuolene in my truck. Got same milage. Gonna try again with warmer weather.
    2006 Limited Busa
    1998 Black bird in need of carb work
    1997 ZX9R still fun to ride
    2006 GPW built THOR. - Sold
    Thanks for building a great bike Greg. And DJ for parting with it.
  10. #10
    DEAD MAN WALKING
    yamahor's Avatar
    Join Date
    Jul 2005
    Location
    Stuart Draft, VA
    Posts
    10,730
    Default
    It does nothing but eat paint and rubber.
    DON'T DO IT!!!!!!
    My myspace page!!!
    My sanity is balanced on two wheels.... Sometimes on one.
    You want Parts? We got Parts. For all your aftermarket parts needs, call Paul. 540-223-3785
  11. #11
    BusaWizard's Avatar
    Join Date
    Dec 2005
    Location
    Kansas City, Mo.
    Posts
    11,451
    Default
    Ye, if the fuel systems engineers stay its bad they know alot more about it than I do. It's definetly a NO GO for me.
  12. #12
    Hayabusa Immortal
    WWJD's Avatar
    Join Date
    Apr 2003
    Location
    na
    Posts
    10,510
    Default
    I bought a $50 magnet for my fuel line once and it aligns my fuel particles for a cleaner spray. I get 175 MPG on my civic now
    HA. If it works, we'll ALL hear about it changing the face of our nation very soon.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
