when we lived in CT we would use one of our kerosene heaters.
Hey Guys,
any ideas on warming up the garage? i got a 2 car carage, detached, and not insulated.
i was thinking of one of those torpedo heaters, run of propane.
what do you guys use?
2002 Canadian Black/Blue
Laguna Seca 2003
Hah ha ha ha ha!!!!!!!!!!
I'm in SoCal, no heating neccessary![]()
Proud owner of the filthiest Busa on the board.
If there's time to clean it, there's time to ride it!!
Nicky Hayden MotoGP 2006 Champion!!
I usually open the garage door and let the AC out.
03 Busa, 06 DRZ400, 08 YZ250 (Lucky #13), 07 TW200, 08 YZ125, 08 TTR 230, 05 DRZ125L,CRF50s and LEM 50s. Bonecrusher Racing family
Smart a$$es. I use a kerosene reddy heater when it gets super cold but my garage is insulated and stays at about 60 year round.
SMOKERS MILITANT GROUP
LOW & SLOW
I get the feeling that folks don't want to hear from us Florida guys in the winter. Have you noticed a difference in attitude lately?Originally Posted by [b
Quote[/b] (bronc3 @ Dec. 11 2005,21:08)]I usually open the garage door and let the AC out.
i have a mr buddy 9000 btu portable propane heater it will take the edge off bu still chilly! i noticed they have an 18000 btu which should heat it up i was thinkin about purchasing a blue flame heater they run off either propane or natural gas they come in 10000,18000,20000,25000,30000, and also come with an optional thermostat controled blower i think the 30000 btu w/blower was 289.00 at home depot and can be wall mounted or free standing with somthin like that you should be able to work in shorts and a tshirt . we have the kerosene /electric torpedo heaters at work the fumes that come off of them are un real bearable if you can leave the garage door cracked but if it is an attached garrage you will get fumes in the house ,big time! i havnt used the propane torpedos ? the blue flame heaters are ventless .
john stein
Its just jealousy. I would move south if I could.Originally Posted by [b
Quote[/b] (Kevin Kesler @ Dec. 11 2005,18:23)]I get the feeling that folks don't want to hear from us Florida guys in the winter. Have you noticed a difference in attitude lately?Originally Posted by [b
LOW & SLOW
thanks.. i was thinking of getting Ready 55000 Btu from Home Depot 139. runs of propane. the tank is like 35 empty and 14 bucks to fill, lasts around 15 hoursOriginally Posted by [b
Quote[/b] (johnstein @ Dec. 11 2005,20:09)]i have a mr buddy 9000 btu portable propane heater it will take the edge off bu still chilly! i noticed they have an 18000 btu which *should heat it up *i was thinkin about purchasing a blue flame heater they run off either propane or natural gas *they come in 10000,18000,20000,25000,30000, and also come with an optional thermostat controled blower *i think the 30000 btu w/blower was 289.00 at home depot *and can be wall mounted or free standing *with somthin like that *you should be able to work in shorts and a tshirt . *we have the kerosene /electric torpedo heaters at work *the fumes that come off of them are un real *bearable if you can leave the garage door cracked *but if it is an attached garrage you will get fumes in the house *,big time! *i havnt used the propane torpedos ? *the blue flame heaters are ventless .
http://www.reddyheat.com/products/rlp50va.html
since i am renting.. otherwise would do the wall mount..
maybe i will talk to the landlord. see if he will go halfers.
I pull mine into the kitchen and work on it.
2010 Kawasaki KLR 650...Orange...yay I'm on two wheels again!
*sold 03 zrx1200r bahloo
*sold*02 Busa Grey/Silver*sold*01 Bandit 1200, *sold*03 Road Warrior, *sold*05 Busa Mitsi Orange,*sold*02 Buell Blast Black, *Stolen*05 Busa Black and Silver
Look for a landmark, campground, or "ace" hardware. Should only be about $8.00 to fill up your tanks.
JD
I use a kersone heater as well. Gets nice and toasty in no time.
2004 Suzuki Hayabusa LE
2004 Honda VFR-800 Interceptor
2006 Honda 599 (CB600F)
2000 Honda Goldwing SE
Insulate, insulate,and insulate , or you will get big temp swings ,causes condensate bad for anything in garage. Plus it will pay for itself with the cost of fuel ,no matter what I would do it first and then would put a ceiling mount TPI electric heater with T-stat control ,last one I put in was only 3.3KW on 230Volts pulling about 12 amps heats a two car garage that is insulated well with no problem.
I feel so much better since I gave up hope!!!!!!
Forgot the good thing about this type of heat ,installed correctly you can go off and leave it and not worry ,set it on low temp and keep the temp in garage more constant.
Also you could make sure you are living on the south side of the hill if you live on the north side..where like here in Ky. you have to pipe in sunlight you will need two heaters.
<!--EDIT|PsychoJoe
Reason for Edit: None given...|1134389827 -->
I have both a Propane tank with heater that does a great job, and I also have a torpedo for the quick heat jobs...
that propane torpedo looks sweet !
john stein
Kerosene heater works real good, fast.
The probability of anything happening is inversely proportional to its desirability.
or you could just have the furnace heat it like in my garage. When the coal furnace was converted to Nat. Gas it makes the furnace a big radiator. Since the apartment above the garage is heated by natural convection it allows the garage (where the furnace is at) to stay a comfortable 65 degrees. It would probably stay warmer if it weren't for the lack of insulation.
2002 Suzuki Hayabusa Limited
Mickey Thompson 7" slick, custom wheelie bars, Lowered
Air Shifter, Slider clutch, 2-step, delay box, PAIR removed
3/4 front race fairing, 17-53 gearing
2004 WVD Street Bike Champ
2005 WVD Super Pro Motorcycle R/U
2006 WVD Spuer Pro Motorcycle Champ
2007 ACD Super Pro Motorcycle Champ
2007 ORP Super Pro Motorcycle R/U
Â* Â* Â* Â* Â* Â* Â*
"If you aren't scared you aren't going fast enough."
"Too Fast?...You can never go to fast!! -- me
It will reach about 23 degrees here today, my toys are in my shop. The shop is insulated, so rarely gets below 30, but when I am out there working, I fire up my wood stove. It'll get the space up to about 70 or so. Warm enough!
'05 BLACK & SILVER.
Speedohealer
Hump mod
Kickstand mod
Acumen gear indicator
Pazzo shorties
Woodcraft stator cover
Brendans seat pins
Brendans tank pins
on the kerosene/diesel heater.... 75,000 BTU
2000 Hayabusa, Blue
1397cc (A.P.E.) 13:1; HMF BigBird exhaust
Brock Cams Stg II/PCIIIUSB; RPM Fuel system/JohnnyCheese Tuned/Tested! Race Tech Suspension/Carrozzerria Wheels; Passport/Bel/Blinder Lasar jammer
2006 FLSTC-I Heritage Softail
2008 FLHTCUI Ultra Classic
2008 Hayabusa, Blue
Yosh TRC full system, Bagster, Passport Redline w/screamer, & LI Jammer
Buell pegs, Pazzo levers, Zumo GPS, Ventura bags
