Yes I know there are threads upon threads of how to tie down a busa.
I am going to try a new steal tie down system on mine, from a guy I met last year at RoT. It hauls around Harleys and other fat bodied beasts with no issue and if all is well the days of straps will be no more.
My question to you guys is this.
Do you think the Swing arm bolt is a good balance location for a tie down system? Ive seen how he has them setup for other bikes and we went into great discussion about movement and balance of the bike. We also got measurements for the whole setup to be made for the busa specifically. I don't personally see any reason why it should not work but would like thoughts.
You can get a general idea here -> Motorcycle Tie Down system by Moki Creations
Bring the side arms back further to pin through the swingarm bolt without damaging fairings.
With the guys current setups for larger cruisers the bikes give no movement side to side, but leaves the suspension free to absorb the bumps you find on the road.
