SkootRRgirl
Considering it is a bit cool outside, the only part that gets cold the worse is my hands. So I thought I wonder if I put on rubber gloves under my gloves in order to keep the heat in. Do you think it would work for a temp. solution to a temp problem? Eventually I will purchase the heated gloves but until then I thought this might help.???
