Thinking about either going to +2 or +3 rear sprocket. Looking for something good for mainly street riding and occasional hitting the dragstrip. Nothing to radical. The reason want to leave the front stock to make it simpler to change to a different gear ratio or back to stock. Witch would be a better way to go?
______________________________________
2003 40th ann. Busa Wolf slipons Muzzy alum fan TRE Puig Double Bubble windscreen PCIIIR Scorpio alarm Backoff brake light Flashing module Freestylecorp undertail Powerbronze rear hugger Mototek front clear blinker lens and rear clear taillight lens |
I'm running +3 (43) on the rear with stock front...It really brings the bike alive. Wheelies are fun too. Recently, switched back to stock rear and took her for a ride.....I'll be switching back to the 43 before I ride again. Roll ons improved greatly as well. Watch the speedo though it will register 7-10 MPH faster without a yeller box, mate. Oh BTW, my buddies ZX-12 finally was able to match my top end though. But off the line I was blowing his wheels OFF!
Thats cool. I'm thinking of doing the swap when I get my friend to change the tires when i get home.
we do alot of the -1+2 combos and alot of the +3 rear sprockets...we stock vortex sprockets which are by far the absolute best aluminum sprocket you can buy...give us a call and we will give you guys the best prices possible on all parts thar we carry...thanks!! dwayne ______________________________________
Cycle Concepts-High Performance Specialists 1625 Lynwood Dr Lancaster,SC 29720 803.285.8093 |
| Quote:
| Quote:
I would go down 1 on the front...Best sprocket mod you can do...If you really want it to smoke coming out then go 16/42 absolutely the best combo period...If you decide to go with alum on the rear check your chain and sprocket without fail or they will fail... |
well. i wouldn't say that it's a bad choice...chain and sprocket wear are determined by the up keep of the two in combination...vortex sprockets are on all the velocity bikes, shootout and 60"...Barry has run the same sprocket all year without failure...i have installed them on busas that make well over 200hp without failure...if you want a sprocket that you can install and forget about it then i don't know what to tell ya...i do know that vortex are the very best aluminum sprocket on the market...don't get me wrong guys, i'm not trying to sell you something here but there are alot of people that have this way of thinking embedded in their minds because they don't have anyone to show or tell them the other side of things...do some research for yourselves and you will see... dwayne ______________________________________
Velocity maintains there races bikes in a meticulous manner...Most owners barely lube their chain...I did all the right things with an alum rear and it ended up looking like the knuckles of my fist...They also run multi stage and slider clutches which is not as hard on the drive train as the oem clutch set up...Also weight is an issue with them they shave everywhere they can...Do life experiences count the value as research *<!--EDIT|STUNNAH Reason for Edit: None given...|1101435753 --> |
| Quote:
btw...life experiences do count for research!! ______________________________________
| Quote:
Also I had 3 Sprokets that were not heat treated correctly and lost 4 teeth on the front on 2 different sprockets from the same lot. I am not an expert but learn from my experience which is why I go with the steel and titanium now. It is a lot more expensive so most likely awash in the end based on cost. <!--EDIT|Ninja Eater Reason for Edit: None given...|1101437618 --> |
| Quote:
| Thread Tools | |
| Display Modes | |
