Results 1 to 6 of 6
  1. #1
    Frank
    POWERHOUSE's Avatar
    Join Date
    Nov 2007
    Location
    east coast
    Posts
    1,489
    Default New raptor dual-mode digital launch/shift light
    This is the new generation of Raptor's Dual Mode shift lights: improved design, able to be programmed up to 20K rpm. Easy to adjust, all controls built right into the light itself. No tach adapter needed, no additional box. This particular version also has an auxiliary output wire which triggers a ground at the shift point - typically wired right into an air shifter kill box to give you the ability to auto-shift.
    This light allows the user to set a desired launch rpm, upper and lower launch limits and shift point setting. Stand alone operation! Although it can be used on almost any bike, or even on cars, on the Busa, this light mounts best right on the small triangular black dash panel under the windshield.
    Example: you can program your launch at 4,000 rpm, +/-200 rpm and your shift point at 10,000 rpm. This would effectively create a launch "window" of 3800-4200 rpm. If the bike is not moving, the light enters into the launch mode automatically. If the rpm was under 3800 (as per this example) the LEDs are off. If the rpm goes above 4200 (again, as per this example), the LEDs would flash rapidly to let you know you are above your launch window. However, within the window (set by you) the LEDs remain on solidly. So all you have to do is bring up your rpm until the light is on solid. Once you are moving, the light goes into the shift mode automatically, where it will come on at 10,000 rpm in this example.
    This light is available in four LED colors (red, yellow, green, blue), and these LEDs are bright and can be seen readily in direct sunlight. The LEDs are so bright, the light comes with two covers - one for nighttime, and one to block the light entirely. Easy install also: power, ground, tach, and speedo signal wire. Dimensions: 3 5/8" long, 3/4" diameter, very compact.
    POWERHOUSE PRICE: $150, free shipping to org members in continental U.S.
    Attached Images Attached Images
    Frank
    POWERHOUSE MOTORCYCLES
    (631)491-6767
  2. #2
    GODSPEED RACING
    frisbee's Avatar
    Join Date
    Mar 2002
    Location
    Tacoma ,Wa.
    Posts
    15,492
    Default Re: New raptor dual-mode digital launch/shift light
    Is it water proof?
    second place is just a name for the first loser
    201.9mph , 1397 kit 206 RWHP (all motor), 3-9" Thompsons arm, BMC Filter, Airbox Mod, Adjustable Rear Links, 1" Reapers Risers, HID Low beam, Carbon Fiber Everywhere, pusher cover
  3. #3
    Frank
    POWERHOUSE's Avatar
    Join Date
    Nov 2007
    Location
    east coast
    Posts
    1,489
    Quote Originally Posted by frisbee View Post
    Is it water proof?
    FB - these lights are NOT waterproof. When placed under the windshield on the triangular dash plate on the Busa, you can go through a driving rainstorm with no problem, that area does not get wet. On other bikes you would have to place the open slot (where the display is) in the down position to avoid getting water in there. It is difficult because of the display and adjustment buttons to actually make this light totally waterproof. Nonetheless, I can tell you that they work great and are smaller and less complicated to install then the majority of lights out there.
    Frank
    (631)491-6767
  4. #4
    GODSPEED RACING
    frisbee's Avatar
    Join Date
    Mar 2002
    Location
    Tacoma ,Wa.
    Posts
    15,492
    Yea , Its hard to find anything thats water tight . I've been looking for a while . The reason I ask is because I live in Washington and here if you don't ride in the rain you don't ride !
  5. #5
    Top Gun
    Pit Bull 13's Avatar
    Join Date
    Mar 2010
    Location
    West Bend ,WI
    Posts
    1,210
    Awesome.. I MIGHT have to look into one
    08 Hayabusa RCC Ultra Turbo
    Build thread http://www.hayabusa.org/forum/turbo/...ver-owned.html
    Built by POWERHOUSE MOTORCYCLES
  6. #6
    Hayabusa Immortal
    GNBRETT's Avatar
    Join Date
    Aug 2011
    Location
    Middle Earth (Connecticut)
    Posts
    2,893
    I have one and got cought in heavy rain and it stayed completely dry. looks great to. and Frank is right they are BRIGHT!
    RCC Super Ultra Under Construction....
    POWERHOUSE Motorcycles
    www.Powerhousemc.com
    email: Powerhouseturbo@gmail.com
    (631) 491-6767
    Frank
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
