jeepinocala
Here is what I am told you help me on this.----The power commander only allows a 10% increase in fuel wich is not enough and a pcIII usb only runs one set of injectors, so the solution is to run two pcIII usbs on both sets of injectors and put the second pcIII on a toggle switch hooked with arming the nitrous so you only have the additional fuel out of the second set of injectors when you are spraying it. Put it on a dyno you ll figure it out.
Is this true?
Is this true?
