Go Back   Hayabusa.oRg > Performance > Nitrous
Reply
LinkBack Thread Tools Display Modes
  #41 (permalink)
Old 10-11-2008, 09:17 AM
Hayabusa Master
Group: Members
Default Re: Nitrous 101, class in in session.
Quote:
Originally Posted by kingofdacoast View Post
I have everything I need. What bottle pressure do you recommend? I want to be as precise as possible.
1000 psi
  #42 (permalink)
Old 10-11-2008, 09:21 AM
Seasoned Pilot
Group: Members
Got it. Anything else I need? I'm going to install the spray bar today and hopefully I can get it on the dyno on Monday. I have the MSD engineer flying in on Monday to work on the SB6 on my big bike so I will send you both runs of the spraybar and wet kit. I'm only running a 50 wet on this bike.
  #43 (permalink)
Old 10-11-2008, 09:48 AM
Hayabusa Master
Group: Members
Nope,that is all you need,just make sure the A/F ratio does not go above 12.4:1
  #44 (permalink)
Old 10-11-2008, 11:40 AM
ToXSicK RoCKeT's Avatar
Hayabusa Master
Group: Members
Quote:
12.4:1? Do you mean No leaner than this, or No fatter? Thx
______________________________________
08 {TOXS!CKBUSA}
If you Sit Like Me, Look Like Me...Grab a Lane Next to ME!
  #45 (permalink)
Old 10-11-2008, 11:54 AM
Hayabusa Master
Group: Members
So just to RE-CAP THIS, The test is what? That a 50hp "wet" "FACTORY STYLE"(meaning nozzle(s) UNDER throttle bodie's) WILL make more MPH in the 1/4 mile than Gixx 1300R'S 100hp "Dry" Single stage spray bar. N2O Kit's will be on the same 08 busa with the same Jockey, and same track. Is this Correct? Thx
08 {TOXS!CKBUSA}
  #46 (permalink)
Old 10-11-2008, 12:08 PM
Hayabusa Master
Group: Members
Quote:
Naturally aspirated engines operate with approximately a 14.7:1 air/fuel ratio (lawn mowers and small engines). However, in Performance engine it's common to have a slightly richer air/fuel ratio,(high reving motorcycles and high performance cars) such as 13:1. When a power adder is used the ratio may be necessary to go as rich 12.5:1 or lower. That's because with power adders comes increased cylinder pressure and with that comes increased heat. And adding fuel actually keeps the combustion from getting too hot, which helps prevent detonation. High octane fuel will also help with detonation since the higher the octane the stable the burn ratio.
  #47 (permalink)
Old 10-11-2008, 12:24 PM
Hayabusa Master
Group: Members
Ahhh...... OK i gotcha....Thx
08 {TOXS!CKBUSA}
  #48 (permalink)
Old 10-11-2008, 12:41 PM
Seasoned Pilot
Group: Members
That is correct. I will be testing three different kits on one bike
My dry nos fogging the air box (40 shot)
Gixx dry spray bar multi-porting setup (100 shot)
Standard NOS wet kit (50 shot)
Everything will be dyno tested first and the track tested (real world as you say).
  #49 (permalink)
Old 10-11-2008, 12:45 PM
Seasoned Pilot
Group: Members
I normally set it where the hp starts dropping off. Normally around 12.5-13 depending on what the bike likes. But it will be on the rich side just to keep cylinder pressure down.
  #50 (permalink)
Old 10-11-2008, 01:40 PM
Seasoned Pilot
Group: Members
Ok toxsick rocket, back to you and our fuel pressure debate. Look at this dyno run of a 1397 busa and tell me what you think is happening. This pull was done today.
  #51 (permalink)
Old 10-11-2008, 04:29 PM
Hayabusa Master
Group: Members
I cant wait to see some numberz(REAL WORLD) Thx
08 {TOXS!CKBUSA}
  #52 (permalink)
Old 10-11-2008, 04:42 PM
Group: Members
Can you post a smaller pic. I need to see the numbers
  #53 (permalink)
Old 10-11-2008, 04:44 PM
Hayabusa Master
Group: Members
Well, Looking at this with an "UNTRAINED EYE" AND NOT being able to see your target AFR #, or ANY other #'s(side of chart is cut off) , But "assuming" it would be around 12.5:1/13.0:1(going off what gixx sayz about keeping her a little fat on the spray, if thats whats your doing, running spray?), i would say that around 7300rpm's(+/- 100) The engine is starting to lean out a "LITTLE", Right?
08 {TOXS!CKBUSA}
  #54 (permalink)
Old 10-11-2008, 05:02 PM
Seasoned Pilot
Group: Members
Redline on bottom graph is 13.0 a/f. What would be your guess of why its running lean? The injectors are maxed and its at wide open throttle.
  #55 (permalink)
Old 10-11-2008, 06:42 PM
Hayabusa Master
Group: Members
My guess would be it needs MORE(volume) injector. NOT MORE FUEL PSI!
08 {TOXS!CKBUSA}
  #56 (permalink)
Old 10-11-2008, 06:45 PM
Seasoned Pilot
Group: Members
Those are s2000 injectors. So do we need to go bigger than that or should they be big enough? Also, why do you think it stops pulling at 10k rpms?
  #57 (permalink)
Old 10-11-2008, 06:49 PM
Hayabusa Master
Group: Members
Is this engine N/A, or N2O?
08 {TOXS!CKBUSA}
  #58 (permalink)
Old 10-11-2008, 06:52 PM
Seasoned Pilot
Group: Members
N/A
  #59 (permalink)
Old 10-11-2008, 07:19 PM
Hayabusa Master
Group: Members
Well, yes, i would have to say the fuel supply is still not big enough! If duty cycle is maxxed out, and it STOPS pulling @ 10k.......Theres not enough fuel volume. Thats ASSUMING all other factors are ok! I would have to believe 42psi would be just fine for this engine N/A, giving it had the VOLUME? Its running out of fuel.
08 {TOXS!CKBUSA}
  #60 (permalink)
Old 10-11-2008, 07:52 PM
Seasoned Pilot
Group: Members
By god I think he's see the light!!!! You are correct it is running out of fuel. The stock fuel pump can't keep up with the demand of the engine. There is nothing on a stock fuel injected motorcycle that can tell the ecu what the fuel pressure is at any given point. It only knows its SUPPOSED to have 43lbs all the time. The ecu doesn't know that the injectors have been changed either. So with this stock pump at 43lbs and bigger injectors maxed out at WOT the pressure drops because the pump can't keep up.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Link to video of my dyno session pward76 Dyno Kings 5 05-28-2007 11:28 PM
First track session Wrath 1/4 Mile 17 09-11-2006 07:42 PM
Weds yak session Kento-Moto General Bike Related Topics 4 07-10-2002 11:13 PM
Weds chat session Kento-Moto General Bike Related Topics 5 04-19-2002 12:53 AM
Dyno session $$??? OB_Mr9R General Discussion 9 12-27-1999 03:57 PM
(c) 1999-2009 Hayabusa Owners Group
