Umm, Remove it if you like after you detonate a perfectly good motor making more power than your using anyway. Then wheel your Toasted bike to the dealership for warranty repairs... Then Hold on cause they are going to be laughing their asses off. The use is going to be pretty obvious, even if you do not have any sign of an install, your motor doesn't lie and the mechanics I work with would recognize it the moment things start coming off the bike. Yeah, no warranty work for you... ______________________________________
No man is so foolish but he may sometimes give another good counsel, and no man so wise that he may not easily err if he takes no other counsel than his own. He that is taught only by himself has a fool for a master. Hunter S. Thompson |
having nitrous on your bike will NOT void your warranty. read the magnuson moss warranty act. the federal law states in a nutshell that a dealer cannot void your warranty for use of non oem parts and accessories unless they can prove that the said part was the casue of the failure that you are trying to have repaired under warranty. now with that said. if you have a bottle strapped to your bike and you roll into the dealer complaining that your brakes are not functioning. they must repair your brakes (provided your warranty covers such item) regardless of that bottle strapped to your side since there is no way that nitrous could have caused your brakes to fail. on the other hand, if you waltz into the dealer with an engine problem where use of nitrous (or any other item such as a turbo or even a bolt on exhaust) could ahve cuased exsessive strain on failed components then you may have some problem arguing that it was not the cause of the nitrous that made it fail. however under federal law, the dealer still has to show proof that said aftermarket accessory was the cause of the failure. at any rate, it is not advisable to roll into the dealer for warranty work on the engine with any signs of a nitrous system on board as it will be tough to argue with them that nitrous did not kill my motor. |
Whats warranty ______________________________________
"Fear is the path to the Dark side, fear leads to anger, anger leads to hate, hate leads to suffering." - MASTER YODA
| Quote:
Hey Revlis, are you using tin foil to read my head again? ______________________________________
I cannot conceive of a God who rewards and punishes his creatures, or has a will of the type of which we are conscious in ourselves. Albert Einstein Mostly Stock 05 Blue/Silver |
| Thread Tools | |
| Display Modes | |
