Go Back   Hayabusa.oRg > Performance > Nitrous
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 10-08-2009, 05:24 AM
Group: Members
Default air shifter
hi,
what is the best air shifter at a reasonable price.how long does the air last and any pros and cons.can you shift without letting up on the nitrous?
thank you
Bluesman
  #2 (permalink)
Old 10-08-2009, 09:29 AM
dadofthree's Avatar
Seasoned Beef
Group: Donating Member
Default Re: air shifter
They actually make a cool set up that basically makes the bike an automatic after you drop the clutch on the line. Experts will chime in soon I'm sure.
______________________________________
Robert
  #3 (permalink)
Old 10-08-2009, 09:48 AM
BlueHaya's Avatar
I'm outta here!!!!
I think it is hard to use shifter and reasonable price in the same sentence.
Alot use Pingel and or make up kits with different parts.
I have a friend with a Muzzy (priced right), but have not used it on the track yet. We just got it set up with a Auto shift from SmithaBusa and the weather turned bad/wet here. Prolly try to get it out and see how well it works when he gets a chance.
SmithaBusa can hook you up with the electronics to make whatever you choose work well.....launch/shift/autoshift. He might have some kit to help with your nitrous as well.
"Don't taze me Bro!!"
"In God We Trust"
"It takes 43 muscles to frown, 17 to smile, but only 3 to perfectly squeeze the trigger"
  #4 (permalink)
Old 10-08-2009, 10:01 AM
Rookie
Group: Members
MPS Auto shifter
spencercycle.com
  #5 (permalink)
Old 10-08-2009, 11:42 AM
Group: Members
I use a Boost by Smith shift light with autoshift output with a cycle-tek airshifter. Outstanding quality and the price is as good as it gets.
09 Hayabusa-Small Stretch, Tsukigi Canon, Spencer's Clamp, Soupy's Links, 46tooth, ECU Editor, Airshifter, SMD Nitrous System
07 BLK NightRod-CFR Pipe, PC-III, K&N Topless, SMD Nitrous System
  #6 (permalink)
Old 10-08-2009, 05:08 PM
GoldenChild's Avatar
DID HE REALLY SAY THAT?
Group: Site Sponsor
Quote:
Originally Posted by bluesman1200 View Post
hi,
thank you
Bluesman
I use mostly MPS Stuff with a mix of my own.Price solely depends on how easy you want install to be..2-300 shifts with co2 and less with regular air,but you can do onboard compressor also..you can shift without letting off nitrous or put window switch inline that kills nos before a set rpm..you can also use a regulator to bring nos bottle psi down to run shifter off same bottle...
Getting You The Right Stuff The First Time To Keep You Riding Longer
www.cloudninemotorsports.com
cloudninemotorsports@comcast.net
  #7 (permalink)
Old 10-08-2009, 05:28 PM
dragracer237's Avatar
Group: Members
I'm using the Muzzy setup on my bike. It kills the fuel for a few mili seconds instead of the coil spark, so you won't get the popping and backfire you get from other air shifters. Schnitz and MPS both sell the kit. Pingels electric shifter does both up and down shift as apposed to just up shift like an air shifter...but has a big clunky lookin shifter solenoid and ugly bracketry
Drive fast,take chances
  #8 (permalink)
Old 10-08-2009, 09:18 PM
New Recruit
Group: Members
Cycletek
  #9 (permalink)
Old 10-09-2009, 11:38 AM
Group: Members
Quote:
I wouldn't want to kill fuel without killing spark on a nitrous application. But, that's just me.
  #10 (permalink)
Old 10-09-2009, 01:55 PM
Group: Members
Quote:
Thats what your fuel pressure switch is for. The other way you have a cylinder filled with raw fuel and nitrous...then when you get the spark back from the coil you get a bis KABOOM...depends I guess on how much nitrous you,re spraying too. I've been on that 180mph fireball. Its a real crappy decision to make weather to stay on and burn or bail off and get fuznucked up!
  #11 (permalink)
Old 10-09-2009, 02:59 PM
bowwow's Avatar
Professional Pilot
Group: Members
I use the MPS kill box with a Bimba air cylinder and a paint ball air tank. It costs me $2.49 to refill the tank and seems to last forever.
  #12 (permalink)
Old 10-09-2009, 03:51 PM
Group: Members
I'd kill the fuel, just not without killing the spark. I've also had fireballs. Just sucks to get a monster detonation when it goes super lean and then you have pieces of engine block, sleeve, and piston taking the leathers and boots right off your lower leg.
Not argueing your use. We all have a preference. Thats just mine.
  #13 (permalink)
Old 10-09-2009, 08:48 PM
Group: Site Sponsor
You guys should invest in window switches...cut nitrous off before shift and bring back on after shift..
  #14 (permalink)
Old 10-10-2009, 04:08 AM
Munchie's Avatar
Rookie
Group: Members
Quote:
Man...never thought of that before...nice idea - and cheap too i'd imagine.
Sorry for the silly question Bowwow, but where do you get the tank refilled? How much $ and how much aggravation setting up for the MPS kill box?
Used to own: 96 Honda VFR - Still miss this one...
01 Blue and Silver Hayabusa - Insurance Company bought this one
Currently: 77 Triumph Bonneville
K8 Black and Grey
  #15 (permalink)
Old 10-10-2009, 04:13 AM
Munchie's Avatar
Rookie
Group: Members
Man...sorry guys - I broke my own rule...jumping into a thread without reading ALL the freakin' posts. Ignore my MPS question...i'll do my homework!
Still curious about where you're getting the tank refilled though
K8 Black and Grey
  #16 (permalink)
Old 10-10-2009, 04:16 AM
Munchie's Avatar
Rookie
Group: Members
+1 on that Dragracer - I like the up/down action but I gotta say I'm not a huge fan of the asthetic quality of the Pingle setup.
K8 Black and Grey
  #17 (permalink)
Old 10-10-2009, 07:53 AM
Group: Members
depends on what kind of arm that you have, every one around here uses arms with air fittings and a onboard compressor. mps is the best bang for the buck, if you got head work done you got to kill the nitrous and fuel with the engine kill. shooting under 15 per cyclinder on a stock engine youll get a crisp pop when you shift but let a rip
  #18 (permalink)
Old 10-10-2009, 08:27 AM
Rookie
Group: Members
I have the Cycle-Tek setup with a 16oz. bottle(co2),has worked flawlessly for over a year and probably get 300 shifts per bottle(fill at local paintball store for $2.00).
  #19 (permalink)
Old 10-12-2009, 01:10 PM
bowwow's Avatar
Professional Pilot
Group: Members
I bought the tank at Wal-Mart, but they don't fill them. I took it to a sporting goods store. I live by a ****'s Sporting Goods. The MPS box was straight foward wiring. I have mine set up through the horn button. I also got a MPS Switch Swapper. I can toggle back and forth from my horn and the air shift.
  #20 (permalink)
Old 10-13-2009, 12:51 AM
Munchie's Avatar
Rookie
Group: Members
Quote:
Hey Nitrous Inj, thanks for the info but I was curious what you meant by "shooting under 15"? Sorry man but I don't follow?
K8 Black and Grey
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Electric shifter or Air shifter WarBux Gen II Busa Information 20 05-21-2009 01:03 PM
air shifter vs dyno jet quick shifter adamwoodham1 General Bike Related Topics 8 02-24-2009 04:01 PM
Which are the best air shifter/electric shifter? hayabusaPuertoRico Busa Mods 35 04-20-2007 07:59 PM
air shifter? OB_blue one Modifications & Aftermarket Equipment 5 05-30-2000 09:48 AM
air tank mountion for air shifter OB_turbo1300 General Discussion 6 02-08-2000 03:08 PM
(c) 1999-2009 Hayabusa Owners Group
