What motor work did u have dne? I am in the process of getting a 1441 kit dne to my bike. Why did u go with aftermarket pump and regulator? What year bike do you have Posted via Mobile Device |
It is a 02, I have a Built 1397 with all the works,I did the aftermarket fuel system because I wanted to go with a small dry shot,and the stock fuel system can not handle the motor's fuel needs and Nitrous needs.The only way was to crush the stock reg to get a bit more fuel pressure,but I just went ahead and got a wallbro 255 pump and a Areomotive reg,the reg can ajust from 20psi to 65 psi.
______________________________________
Yeah, I know Quantum Motorsports |
| Quote:
I have an 08 and am doing 1441 as I already said, If I do a dry shot, I will have to get either the 2nd PCIII for the other set of injectors or dump the one I have and get a bazzaaz. The fuel curve will need to be adjusted to high for the single PCIII if n2o is used. Through my research the stock injectors and pump will be able to handle the fueling issue of a 50 or below n2o shot, as long as I can get it dialed in on the PCIII/'s. ______________________________________ Jason 2008 busa Orange and Black (officially 1441) (shhhhhh, dont tell everyone that its the fastest color). http://www.horizonpowder.com/ http://www.bluegauges.com |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| MPS Fast FI / Fuel Addition Questions | AugeredIn | Nitrous | 13 | 03-03-2010 05:35 PM |
| Why not teka vs. pc/mps fast etc???? | CAT3 | Engine and Performance mods | 8 | 09-27-2006 04:09 PM |
