Go Back   Hayabusa.oRg > Hayabusa Ride Faster > New Owners Forum
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 07-03-2005, 03:03 PM
New Recruit
Group: Members
Default
I'm still new and still trying to understand bikes in general, I'm going to start off on a gsxr600 or katana, whichever I can find for cheaper, but while doing my research on things I'd eventually like to do to my future busa, I've come across the whole "front and rear sprocket gearing" thing. Basically I'm wondering how one goes about changing the gearing, and EVERY little thing one needs when changing the gearing. Does anyone know what stock gearing is? and I'm one of those lunatics obsessed w/ top speed...so I'd want something to allow for 200mph near redline in 6th w/ basic bolt ons, pc3, etc. Thanks for the help and putting up with my nubness.
  #2 (permalink)
Old 07-03-2005, 04:54 PM
The Big Red One's Avatar
Hayabusa Legend
Group: Members
Default
The Busa's geared to go 200 at the redline in sixth. Under perfect conditions, with a full exhaust/pc and a good pc map, it should prolly be able to do it....a stock Busa was clocked at 200.2 in England. But all the Busa's since 2001 I believe are restricted to 186, so you would also need to buy a $30 de-restrictor.....and of course find a place suitable enough to go 200 The stock gearing is 17 front and 40 rear. Hope this helps
  #3 (permalink)
Old 07-05-2005, 12:28 AM
New Recruit
Group: Members
Default
Quote:
Originally Posted by [b
Quote[/b] (The Big Red One @ July 03 2005,10:54)]The Busa's geared to go 200 at the redline in sixth. Under perfect conditions, with a full exhaust/pc and a good pc map, it should prolly be able to do it....a stock Busa was clocked at 200.2 in England. But all the Busa's since 2001 I believe are restricted to 186, so you would also need to buy a $30 de-restrictor.....and of course find a place suitable enough to go 200 * The stock gearing is 17 front and 40 rear. Hope this helps *
are they rpm restricted or just speed restricted? I've been looking at others threads about top speed in their stock bikes and have noticed they hit like 182 or 186 @ 10,800 rpms...isn't that where the busa redlines? Personally I'd like to hit 200mph without having to take the bike 800-1k rpms beyond redline or anywhere beyond redline for that matter.
I'm still a little confused as to how one goes about changing the gearing, b/c dont u need to buy new sprockets for the gearing you want and a new chain to go with it? or am I completely off here?
  #4 (permalink)
Old 07-05-2005, 02:16 AM
BA BUSA's Avatar
MotoGP Wannabe
Anime BlackJack Champion
Group: Donating Member
Default
10,200 in sixth = 186
redline is 11,000
  #5 (permalink)
Old 07-07-2005, 04:34 AM
New Recruit
Group: Members
Default
Quote[/b] (BA BUSA @ July 04 2005,20:16)]10,200 in sixth = 186
redline is 11,000
is 11k redline or where the factory tach stops reading? granted im new to busas and bikes, but I know most of the time just b/c tach reads up to 11k doesnt mean it redlines there. (sorry if it sounds like Im insulting ur intelligence, Im not, I dont mean to be rude, I just see all the time how people say redline IS 10,800 period)
Also, anyone know about having to change the chain when u change gears? or is it all in the sprockets?
  #6 (permalink)
Old 07-08-2005, 06:08 PM
Hayabusa Legend
Group: Members
Default
Quote[/b] (DSMGSXGuy @ July 06 2005,22:34)]
redline is 11,000
You don't need to change the gearing to go 200...its geared stock to go 200 at the indicated redline which is 11,000. You just need a little more power and perfect conditions.
The tachs on most bikes are usually off some and the Busa's no exception.....at 11,000 indicated its actually only spinning 10,800. And the Busa's rpm restricted in top gear so it only revs to 10,200 instead of 10,800 (or 11,000 indicated)...thats why it only goes 186. But a $30 TRE will fix that
Unless you have alot of miles on your chain and sprockets you can just change sprockets alone. The chain has nothing to do with gearing...thats strictly controlled by the sprockets.
  #7 (permalink)
Old 07-08-2005, 07:14 PM
Default
200 is purty fast, ride one in stock trim and see if you really need to go any faster. I recommend changing the chain whenever you get new sprockets.
______________________________________
2004 Blk/Pur: BDE Gen-3, PC3r, Block off plates, scorpio alarm, Trac triple, Trac 6 inch over polished swingarm, dog bones, motorhead undertail, air box mod, Zero Gravity Smoked DB, Smoked Carbon Signals, clutch slave support, bar ends, muzzy alum fan, ZVM Chain, 16 tooth front, 42 tooth back.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
(c) 1999-2010 Hayabusa Owners Group
