Yes, the low stays on with the high. What in the manual makes you think it shouldn't?
______________________________________ |
maybe they were talking about when the bike is off.
2006 Raiment White Hayabusa Lumen Junkie in Residence, pm me for HID retros ![]() Why retros are safer than HID kits |
Welcome ... and +1, it's normal.
2008 Hayabusa - PC3, Yoshimura TRC full system, Corbin seat, SWMotech Tail Rack + Givi case, MRA Vario Touring Screen, Soupy's Bar Risers 1997 CBR1100xx - Jetted, Full Muzzy system, Corbin seat, Givi Wingrack and Bags, Givi screen, Helibars, 5.5 gallon auxiliary fuel cell |
| probably not explained to well i guess, but holding any switch in between functions will sure to cause damage
99 red/black carbon can co ex bmc filter few other mods Â* Â* Â* Â* Â*tell it like it is
Welcome to the forum. ![]() ![]() About the lights, only one is supposed to be on, either dim or bright. It's explained in small print in the back of your book. During the run in period, both are on during bright. After run in you are supposed to change that as per the manual, it puts more amps through the high beam and switches off the low beam. To do this after run in, follow the instructions on page 413. It's explained as follows: "After 1,500 miles, crest a small hill at 160mph, while both wheels are airborne, change from bright to dim three times and the ECU will recognize experienced rider mode and switch the light circuit to 'post run-in' mode." ______________________________________
Busa K9 Silver Husqvarna TE610ie |
Seems the high beam would be shiddy by itself anyway, more of a long distance laser pointer of sorts to me. The low spreads a nice flat beam directly in front of the bike for about 150' then fades out where the high beam takes over and puts out a more central beam directly in front of the bike up to about 400'.
______________________________________ Put yourself on the ORG member map!!http://platial.com/mapv/HOG/627298# |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| HID Delay for low and high beam? | Vonderbach | Electrical Mods | 8 | 04-22-2009 08:38 AM |
| 2006 Busa' High and Low Beam Bulb sizes? | s4play | Electrical Mods | 19 | 06-26-2008 11:37 PM |
| 6000k high 8000k low beam | gsx1300Rrr | Appearance mods | 4 | 05-24-2008 10:54 PM |
| Switch low beam for high beam? | Churchkey | General Bike Related Topics | 7 | 02-05-2006 04:10 PM |
| Front High Beam Low Beam Change... | babuski | General Bike Related Topics | 16 | 11-15-2005 10:15 PM |
