17-16 tooth front sprocket
OB_gsx1300rguy
Hey when you guys changed from 17 to 16 on the front sprocket did you transfer that rubber damper thats on the stock srocket to the new one?
NO. but stock is 18 ..? I put a 16 tooth on my bike for about 30 min. WOW that was too much, unless you only want to use it on the drag strip and then its still A LOT!
I could wheelie at 1/2 throttle in first and 2&3 came up like first does with the a 17 tooth sprocket.
I have news on how to fix the speedometer error that occur when U are changing sprockets( and its almost for free ). Only I wont say this on this board. Chase might not like it.
