| Garage | .oRg Forums | Portal | Blogs | Arcade | Gallery | FAQ | Classifieds | Calendar | Chat | Mark Forums Read | Sponsors |
| | LinkBack | Thread Tools | Display Modes |
Well, the chain was ready to be replaced (12k miles on the stock chain). *A while back I ended up buying a new stock chain off of ebay for a good price, brand new take off for around $40. *I had to order the master link, which I ordered two (wanted a spare) $5/each. *So, I had the material there for some time, I had the tools but I never replaced the chain before, so I decided to do it and take pictures to walk anyone else through it. The whole process took less than an hour, I was just taking my time, taking pictures, probably could have been done in about 20 mintues. Tool used: Motion Pro Jumbo Tool ![]() Micrometer ![]() Dremel Tool Safety Wire (Chain puller - not necessary) ![]() Section 6-84 through 6-87 of the manual and the ability to read So here is the stock master link. ______________________________________
2006 Burg/Black ![]() If you love your bike, set it free. If it comes back to you---you probably highsided!! Countdown to Busa Bash FALL 2008 --> http://www.7is7.com/otto....%20BASH |
I wanted to grind down one of the pins so it would be easier on the tool to push out. ![]() ![]() Installed the Motion Pro Jumbo Chain Tool, with the pin extraction adapter. ______________________________________
Extracted the pin by screwing the inner threaded piece in. ![]() Removed the original link, and staged the replacement chain in place to be safety wired to the origianl chain so that the chain can be rolled off and the new chain rolled on. ______________________________________
Wired together ![]() ![]() Used the chain puller to pull (more like hold) the chain together to install the new master link. ![]() New Master link and O=rings ![]() ![]() ![]() ![]() Used the press attachement to press the connector plate on and pressed until the the width was within tolerance (21.85 - 22.15mm). ![]() ![]() ![]() That's better ______________________________________
Now set the tool up to stake the joint pin, using the tool adapter and measured to ensure it's within tolerance (5.45 - 5.85mm). ![]() ![]() ![]() ![]() ![]() ![]() ![]() The staked pins didn't turn out as good as I thought, I might redo, I think I was rotating the tool too much while trying to torque on the tools staking pin. That's it. Easy with the right tools. ______________________________________
I just figured out that I didn't use the right piece to stake the pins... I will know for the next time... ______________________________________
That's why I bought a spare. I plan on redoing, it's a lot easier to do it right than to have a problem down the road. Cheaper too.
If I get a chance tomorrow I will take a picture of the mushrooming pin adapter and the pin properly staked, then it will be suitable for pinning. THanks, Ted
Nice write up!
04 LIMITED BUSA, 1397 kit, intake cam swap, 50hp wet NOS kit! 92 GSXR 1100/1216 THE BABY I JUST CANT GIVE UP 99 BUSA, SOON TO SEE THE ROAD AGAIN |
Re-do on the link staking... Grinded the pins, used a different chain breaker (I just happened to have laying around) and repeated the process using the correct staking adpater on the tool.. ![]() ![]() ![]() ______________________________________
04 Blue/Silver: Chrome RS-3's Power Commander 16/42 hump mod (inside and out) dampner mod K&N EBC pads & rotors screens Suzuki gel seat busa hand grips air box mod galfer front lines Throttlemeisters |
No problem... if you are able to plan the change, I will be willing to loan the tools out...
Great post! Thanks for taking the time!! ______________________________________
I used to own: '00 zx9r ninja '05 dodge magnum But they were taken away from me ![]() Pictures of a few GTGs. 1 @ Wilmington 1 @ Mount Morrow 1 @ Greensboro Spring Busa Bash 08 Checkout: www.186pix.com Speed Restricted pix |
| Thread Tools | |
| Display Modes | |
