| Garage | .oRg Forums | Portal | Blogs | Arcade | Gallery | FAQ | Classifieds | Calendar | Chat | Mark Forums Read | Sponsors |
| | LinkBack | Thread Tools | Display Modes |
I also want to remove my tire/wheels to have new tires mounted. The first challenge I ran into is removing the front wheel. you will need a 24mm External Hex do-hicky... You will also need a 36mm socket for the rear... I tried the make-shift tool that clymer suggest, but it will not budge the front wheel bolt...
______________________________________
04 CBR1000RR 06 GSX 1300R |
<div> (xcrypto @ Aug. 15 2007,04:49)</div><div id="QUOTEHEAD">QUOTE</div><div id="QUOTE">I also want to remove my tire/wheels to have new tires mounted. *The first challenge I ran into is removing the front wheel. *you will need a 24mm External Hex do-hicky... *You will also need a 36mm socket for the rear... * I tried the make-shift tool that clymer suggest, but it will not budge the front wheel bolt...</div> loose'n up the right pinch bolts (brake side) and leave the left tight (clutch) should roll right off ______________________________________
2006 LE shinny stuff/small air box mod/P.A.I.R mod/GiPro/+1 bones/Yoshi R22's/muzzy fan/PCIIIusb/Pipecross air filter |
yeah was wondering what tool was needed as it definetly isnt a standard nut/bolt set up
______________________________________ Mod list (2006 RED/BLACK) *Tobin seats *Clear alternative integrated signals (dark smoke)*Polished aluminum Kanji upper triple tree *Throttlemeister heavy bar ends*Magical Racing windscreen*Woodcraft Stator cover*T-rex No cut sliders*Pilot power 2 CT's*Pazzo levers*PCIII |
Within this forum is a .pdf shop manual that covers most anything mechanical. There is a tool specially made to remove the front axle but you can use to two large nuts jammed together on a large bolt. Just stick the nuts inside the opening and spin the bolt with a wratchet. Like stated earlier, just loosen the pinch screws on the right side first, loosen off the fender and remove the caliper bolts too. The rear is a breeze but you'll need a 36mm socket. There are short cuts like using the tool that came with the bike but you cant torque the axle back in with it. Surf around this site and you'll find more than you need. ______________________________________
Among the OVERLY moderated... |
Post is needs pictures... ______________________________________
2006 Burg/Black ![]() If you love your bike, set it free. If it comes back to you---you probably highsided!! Countdown to Busa Bash FALL 2008 --> http://www.7is7.com/otto....%20BASH |
thank you for pics going to look into putting that tool together... what size bolt /nuts did you use if you don't mind ______________________________________ Mod list (2006 RED/BLACK) *Tobin seats *Clear alternative integrated signals (dark smoke)*Polished aluminum Kanji upper triple tree *Throttlemeister heavy bar ends*Magical Racing windscreen*Woodcraft Stator cover*T-rex No cut sliders*Pilot power 2 CT's*Pazzo levers*PCIII |
My only concern with taking the rear wheel off on myself is lining up the wheel and tensioning the chain properly. I need to get a couple of tools to make that easier for me. I get a good deal at the dealership since my good friend is the service manager, so I usually just take the bike there and let them deal with it, plus it's only like an 8 minute ride.
<div> (xcrypto @ Aug. 15 2007,04:49)</div><div id="QUOTEHEAD">QUOTE</div><div id="QUOTE">I also want to remove my tire/wheels to have new tires mounted. *The first challenge I ran into is removing the front wheel. *you will need a 24mm External Hex do-hicky... *You will also need a 36mm socket for the rear... * I tried the make-shift tool that clymer suggest, but it will not budge the front wheel bolt...</div> Did you loosen the four axle bolts on the fork ______________________________________
Robert
Yeah, well my local dealer changed my first rear for $100.00. TAKE GREAT CARE WITH THE ROTORS GUYS OR THAT SAME DEALER WILL GET $250.00 a package from you. The chain tension alignment is very simple. Note where the blocks are before disassembly and put them back ______________________________________
Robert
Yeah watch the rear rotor, I took mine off for the first time and didn't notice the rotor touched the rim as I rolled it out and scratched the rim 1/2 way around ______________________________________
His : 06 Le Hayabusa Â* Â* Â* Â*Tobin seat Hers: 06 Le Hayabusa Â* Â* Â* Â* Tobin seat Â* Â* Â* Â*Â* 2" lowering links Ride safe.......BUT.....Do it Fast !!!!!!! |
| Thread Tools | |
| Display Modes | |
