Good idea there Bill![]()
Paul do you sell these? I may come to the mountains for a valve check![]()
Greg
"Obstacles are those frightful things you can see when you take your eyes off your goal." - Henry Ford
<div>
(bigoltool @ Feb. 04 2007,05:58)</div><div id="QUOTEHEAD">QUOTE</div><div id="QUOTE">Sounds like a damn good plan Bill! Unfortunately I haven't had mine long enough to collect any shims as yet. One possible detriment to this plan may be that a lot of folks are just plain not willing to attempt to adjust em themselves! Though they would still get their old shims back from the dealer!</div>
big...it shouldn't be too daunting for the novice home mech to perform this task...per the shop manual page 2-8 in the "Periodic Maint." section outlines the procedure quite nicely...with the most scarey part being "Cam Removal" (should you need to swap out some shims) which isn't really all that scary at all and is covered in section 3-28...15 minutes of reading and your average DIY type will feel nearly confident and competent...and after post an in depth pictorial tutoring on the subject?...it should be "Just Follow Thew Step-By-Step Instruction/Pictures" childs play.
and outside of a good ratchet set?...the only non-typical special tools we may need will be a torque wrench and a magnet.
L8R, Bill.![]()
"I'm Imprisoned By My Addiction To Speed...But I do Recieve Kanjical Visits On A Daily Basis."
<div>
(JINKSTER @ Feb. 04 2007,11:06)</div><div id="QUOTEHEAD">QUOTE</div><div id="QUOTE">SIZE * * * ORDER# *SIZE * * * ORDER#
1.35 mm *035-200 * 2.35 mm *035-220 *
1.40 mm *035-201 * 2.40 mm *035-221 *
1.45 mm *035-202 * 2.45 mm *035-222 *
1.50 mm *035-203 * 2.50 mm *035-223 *
1.55 mm *035-204 * 2.55 mm *035-224 *
1.60 mm *035-205 * 2.60 mm *035-225 *
1.65 mm *035-206 * 2.65 mm *035-226 *
1.70 mm *035-207 * 2.70 mm *035-227 *
1.75 mm *035-208 * 2.75 mm *035-228 *
1.80 mm *035-209 * 2.80 mm *035-229 *
1.85 mm *035-210 * 2.85 mm *035-230 *
1.90 mm *035-211 * 2.90 mm *035-231 *
1.95 mm *035-212 * 2.95 mm *035-232 *
2.00 mm *035-213 * 3.00 mm *035-233 *
2.05 mm *035-214 * 3.05 mm *035-234 *
2.10 mm *035-215 * 3.10 mm *035-235 *
2.15 mm *035-216 * 3.15 mm *035-236 *
2.20 mm *035-217 * 3.20 mm *035-237 *
2.25 mm *035-218 * 3.25 mm *035-238 *
2.30 mm *035-219 * 3.30 mm *035-239
and here's the link to SUDCO 9.5 Valve Shims Page....
http://www.sudco.com/95valveshims.html
Pretty reasonable to as Suzi OEM shims are about $8 ea. Sudco imports and sells them for $5-$5.50 ea.
L8R, Bill.</div>
One of the site sponsors has the OEM shims listed for $4.21 each and I have seen them as low as $3.71 each. In the service manual and online I couldn't find any shims listed smaller than 2.30 so that would rule out needing almost half of the shims on your list.
2000 blue/silver MCX intercooled full exhaust...sleeper
Obviously they do. Thought someone at my local dealership said they didn't. My bad.![]()
Robert
This sounds like a great idea. I have to check mine as soon as the weather warms up.![]()
Rob
'02 SE
<div>
(jjmetheny @ Feb. 04 2007,07:20)</div><div id="QUOTEHEAD">QUOTE</div><div id="QUOTE"><div>
L8R, Bill.</div>
One of the site sponsors has the OEM shims listed for $4.21 each and I have seen them as low as $3.71 each. Also the majority of online sites list only 9 (2.30-2.70) different shims instead of the 25 (2.30-3.50) that are available, which would make me think that maybe those are the most common ones used. In the service manual and online I couldn't find any shims listed smaller than 2.30 so that would rule out needing almost half of the shims on your list.</div>
and then the guy who's got his busa 1/2 torn apart discovers he needs a 2.25 shim...or a 2.75 shim...and then what?...he's sorta screwed...and we've succesfully defeated the whole purpose of the shim bank...right?...now he cusses me and the freak'in shim bank idea...nope...that's not the sorta thing i'm looking to accomplish here..however..I do agree that we should stock up heavily on the more popular mid-range shim sizes but should also have a few of the oddballs on hand for "just in case"..granted...we may not ever encounter a single valve throughout all hayabusa.org that actually needs a 1.35mm or a 3.3mm shim (and if they do?..they probably have more serious problems than just a valve adjustment issue) but..we should have at least 1 of each of even the low/high spectrum oddballs...especially at the prices you mentioned...it wouldn't hurt...JMHO and L8R, Bill.![]()
Great idea Jinks. Mines up on 40k and doing it right off. Extras will goyour way if this flies & I'll check at my local dealer, he's a pretty good guy and a busa rider since '99. He may come up with something to add.
Did the NABT '05(North American Busa Tour 2005) Maine - Myrtle & Laconia BWs, than Alaska, Glacier & Yellowstone Parks, to Sturgis and home. What a RIDE!!!
"Hey, nice bike, what I saw of it."
I'm just trying to save someone from buying shims that would never be needed, like the 19 sizes (1.35-2.25) that you listed that are smaller than the 25 sizes (2.30-3.50) that are listed in the service manual. Take those 19 shims if you bought 2 of every size, that's over $150.
You could replace every shim for 2 motors for that amount.
Good idea, Bill!
I'll be pulling my motor out real soon - will do the adjust after the cams are back in. If I have any left over, I'll shoot them your way!
'04 Blue/Silver
Bill, send PM your address and I will send you a check.
2006 Burg/Black
If you love your bike, set it free. If it comes back to you---you probably highsided!!
is this what we need to do the valve adjustments? my bike is also getting there 13,000 miles
http://cgi.ebay.com/ebaymot....=1&rd=1
I also found this website not bad price I think.
https://www.cycle-parts.com/parts-l....lve.asp
You can count on me for contributing to this. As mentioned before, maybe we can organize this so we can cover any possibly needed sizes, if we get enough involvement.
didn't read all the gobbly gook.... but the first to things to try are:
1 - measure all the tolerances and record the shim # in a log. then see which of those shims can be relocated to another valve. This can decrease the number of needed shims greatly.
2 - Find a smaller shop in your area (dealers may help depending on your relationship with them) .... and do an "exchange" with them for the right shim you need.
I have found this to be a successful plan of attack for many bikes in the past.
and those ... generic kits may not be as far off as you might think.
Political Correctness:
'Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.'
Hey i had some of those but they said Rorer on em! Don't know where or how they got there *The way most here baby their baby! Won't that be needed after 18k atleast ? *
I talked with the service manager when I did the valve adjustment on my Rex a few years ago - and he let me swap out the shims I needed. Hopefully I will be able to do the same this time (my Busa just passed the 15k mark).
If I can't do a swap with the dealer I would be interested in the shim bank.......
Bill,
I agree, we should stick with OEM or a known quality shim. The exchange coming back should be the same. I think if we covered the same sizes as the Service manual quotes it should be sufficient. The 9.5mm fits a bunch of applications so it does not surprise me that Sudco offers 40 sizes.
I’m betting if someone needs a 1.35 mm shim in a busa, something is not right. Valve/seat cut wrong, aftermarket cam with a screwed up base circle, something, but they have much bigger problems to worry about than the shim bank not having a 1.35 shim.
What is the 035-006 kit available for? Maybe we could get a board sponsor to “sponsor” this by selling the kit and/or OEM shims to us at cost. I know my Sudco account is long gone.
I’ll buy in on the deal, but I think getting shims outside of 2.3-3.5 range is wasted money that could be spent having a deeper coverage.
03 AE
I have seen the Sudco 035-006 kit for around $240 and it includes 40 shims, 2 each of (2.35-3.30), about $6 per shim. I have seen the factory shim kit 12800-41810 for around $370 which comes with 105 shims, 5 each of (2.50-3.50), about $3.5 per shim.
so we doing this or what
make this a sticky or start a new thread in maintenance and sticky
<div>
(jjmetheny @ Feb. 07 2007,15:55)</div><div id="QUOTEHEAD">QUOTE</div><div id="QUOTE">so we doing this or what
</div>
How about both... give me a few minutes
03 AE
