Go Back   Hayabusa.oRg > Technical > Maintenance and Do-It-Yourself
Reply
LinkBack Thread Tools Display Modes
  #21 (permalink)
Old 02-26-2006, 09:23 AM
Pipefighter248's Avatar
Bling Blam!
Group: Donating Member
Default
Bill, I think they are asking why you put the Vacuum lines like you did at the end?
I'm wondering myself.
  #22 (permalink)
Old 02-26-2006, 09:24 AM
Banned Permanently By MC Mustang
Default
Wow! What a great tutorial. I would never had know about this.
Why wouldn't it come from the factory all balanced? Or does it and after some miles and mods,things change?
  #23 (permalink)
Old 02-26-2006, 09:32 AM
Ride_or_Fish's Avatar
Default
I just wanna say how glad I am to see threads like this that aren't about inane and irrelevant questions or polls, and simply about the bike!
Thank you Bill.
______________________________________
Distance = Speed * Time
"Illegal immigrant" is an oxymoron.
"In God we trust, all others bring data" *-- W. Edwards Deming
  #24 (permalink)
Old 02-26-2006, 09:42 AM
Default
Great tutorial! You made it look easy - I'm ready to get a manometer and give it a try!
I was also wondering why you reconnected the vacuum hoses the way you did instead of as originally done?
  #25 (permalink)
Old 02-26-2006, 09:44 AM
BusaSamurai's Avatar
There Can Be Only One INSTIGATOR * * * *
Default
Thats pretty good im a back yard mechanic and do most of the stuff on my bike But this is one I dont think I will attempt ..Might talk to a friend of mine about it ans see what he says . But my luck is it wouldnt run after words or it would be one of the oh Shid days..not worth the risk ..But looks pretty straight forward..You did a good job of explaining ...
05LE Fastest Color
Muzzy Full Exhaust
PC USB
So ON & SO Forth
And #1 Instigator
www.GrudgeBike.com
  #26 (permalink)
Old 02-26-2006, 09:59 AM
Formerly known as "Zuki"
Default
OK, I need clarity on this. I thought the middle cylinders (the ones with longer stacks) were suppose to run richer than the two cylinders with short-stacks? If you synched all four the same, is it the stacks that actually richen the 2 middle cylinders? Or are the 2 cylinders in the middle suppose to be set a little richer than the 2 cylinders with the shortstacks?
I ask this because of a possible Lean condition on the middle cylinders while using nitrous. If all cylinders are synched the same, would the middle cylinders (The 2 running longer stacks) come into a lean condition while on NOS? If you look at the billet velocity stacks, all 4 are short stacks...I guess lots of Nitrous users use velocity stacks, or run all stock short-stakcs. Now if you synched all four cylinders the same while running all short stacks, wouldn't you encounter that lean condition if all throttle-bodies were synched the same?
I know with the PC3USB, I thought this gives the Dyno tune expert the ability to richen or lean each cylinder where the pc3r wouldnt allow individual cylinder adjustment. Thus the push for guys to buy the usb version and if timing was needed to be added or taken out the optional timing unit is avaliable to purchase for the usb version...yes much more expensive, but the ability to richen or lean each cylinder could make a huge difference for a racing application.
Help me understand all of this.
  #27 (permalink)
Old 02-26-2006, 10:09 AM
I Love my Wife!
Default
Quote:
Originally Posted by [b
Quote[/b] (pipefighter248 @ Feb. 26 2006,03:23)]Bill, I think they are asking why you put the Vacuum lines like you did at the end?
pipe...here was my response to the same question posed on another board...
Almost 5 years ago I introduced the FZ1OA too "Jinksters 4-Way X-Over Manifold"....based on the old yamaha "Balance Tube" the seca's usta use known as Y.I.C.S. (yamaha induction control system) but I made'em up of fuel line and brass "T" fittings to eliviate any special tools need for blocking off the metal balance tube of the yics for individual carb synching...and I linked all 4 CV Carb nipples together...much like what you see on the stock busa arrangement here...and the FZ1 ran far smoother and actually gained nearly 7ftlbs in low-end torque dyno-dyno...and I sold out of'em...to the point that a guy bought the one right off my own personal FZ1...and while waiting for more barbed brass T-fittings to come in?....I just linked 1 too 4 and 2 too 3 and liked the results just as much if not moreso...with no brass T fittings involved...that's why I didn't hesitate to do what I did as looking under the tank of my busa was a surprising oh so familar shock to me...as I was so familiar with what exactly was going on.
However...just for security, piece of mind, and less questions? I may go ahead and swap it back to stock oem configs..and...L8R, Bill
"I'm Imprisoned By My Addiction To Speed...But I do Recieve Kanjical Visits On A Daily Basis."
  #28 (permalink)
Old 02-26-2006, 12:43 PM
gtrpimp76's Avatar
S.Q.U.I.D. Extraordinaire
Default
SHOULD BE MADE STICKY!!! I will do my own adjustments too.
SOLD ?
2005 Hayabusa black/grey: BDE GEN3 STREETSMART FULL EXHAUST.
2006 GSX-R1000: Yosh TRC, PCIIIUSB, Ign Module,Quickshifter,Race Tech rebuild/respring, Elka 3 way adj hydraulic Shock w/remote ride height & preload adjuster.
  #29 (permalink)
Old 02-26-2006, 12:57 PM
Rookie
Group: Members
Default
I had mine done last Thursday at the dealer along with my oil change and tuneup. They said it wasnt due until 7,500 miles but went ahead and had them do it a little early so I wouldnt have to go back. All the work I had done was $200 and I have no problem paying that. I'd rather someone who knows what they're doing work on my bike. I'd screw it up for sure and besides, I really hate working on anything mechanical. I guess some people enjoy wrenching like I enjoy riding, golf, skydiving, and a million other things. Time is precious!
  #30 (permalink)
Old 02-26-2006, 04:03 PM
I Love my Wife!
Default
Quote[/b] (valium @ Feb. 26 2006,03:59)]OK, I need clarity on this. I thought the middle cylinders (the ones with longer stacks) were suppose to run richer than the two cylinders with short-stacks? If you synched all four the same, is it the stacks that actually richen the 2 middle cylinders? Or are the 2 cylinders in the middle suppose to be set a little richer than the 2 cylinders with the shortstacks?
nope....what you are adjusting here are the butterflys in the throttle bodies....which are downstream of any inner stack/airbox flowpaths...and you are simply "synchronizing" the butterflys unto each other...so that all are pulling the same vacume/velocity...with all four working together in perfect harmony...as multi-carb/t-body engines that are out of synch is like a four piece band that's out of....
tune.
BTW....I just synched Ride_or_Fish's new hayabusa but minutes ago...and will be doing Dakkines sometime this week after work..they both just left after helping me line up my fairing and I took a ride on my beast with the t-bodies synched and the new akro race and...OMG!
L8R, Bill.
  #31 (permalink)
Old 02-26-2006, 08:56 PM
Default
Bill, thanks a bunch for spending time on my bike. Besides having learned a thing or two, I think the bike is running glass-smooth!
  #32 (permalink)
Old 02-26-2006, 11:07 PM
frisbee's Avatar
GODSPEED RACING
Default
Very cool write up Jinkster!
second place is just a name for the first loser
3-9" 600 arm, #36 dry NOS, 208HP @ 137FT LBs Â*,BMC Filter, Airbox Mod, Adjustable Rear Links, 1" Reapers Risers, Yellow ZG DB, HID Low beam, Icemann Yellow Hi beam, Speedhut gauges, Carbon Fiber Everywhere, pusher cover
  #33 (permalink)
Old 02-26-2006, 11:10 PM
I Love my Wife!
Default
Quote[/b] (Ride_or_Fish @ Feb. 26 2006,14:56)]Bill, * thanks a bunch for spending time on my bike. Besides having learned a thing or two, I think the bike is running glass-smooth! *
NP Paul...glad I could be of some assistance...and yeah....she seemed to run glass smooth to me.
  #34 (permalink)
Old 03-01-2006, 06:45 PM
Group: Members
Default
wow...I just bought my busa and was going to sell my gauge set when I sold my old R6...this is the first fuel injected bike I've had and I figured there was no synching involved...thought i'd never have to synch carbs again...little did I know i'd have to synch fuel injection...oh well, what are ya gonna do?
  #35 (permalink)
Old 03-01-2006, 08:04 PM
Default
That is a great write up. Thanks Bill. But you gota explain to us mecanical rookies like me what hooking the vacuum hoses like that will do? Sorry I question if it will do anything but give the vacuum sensor a weak signal.
  #36 (permalink)
Old 03-01-2006, 08:10 PM
I Love my Wife!
Default
Quote[/b] (ga1990 @ Mar. 01 2006,12:45)]wow...I just bought my busa and was going to sell my gauge set when I sold my old R6...this is the first fuel injected bike I've had and I figured there was no synching involved...thought i'd never have to synch carbs again...little did I know i'd have to synch fuel injection...oh well, what are ya gonna do? *
yep...true story...as buying a FI'ed bike only means that "Just The Fuel Is Injected" but...not the air that accompanies it...which is metered through your throttle bodies...via the throttle position of the butterfly valves in the throats of those throttle bodies...all four of'em...and if they ain't in synch?...performance suffers and..enter "Excessive Engine Vibrations".
and no...I'm not really this smart but I did sleep at a holiday inn express last night.
L8R, Bill.
  #37 (permalink)
Old 03-01-2006, 08:17 PM
I Love my Wife!
Default
Quote[/b] (hooken203 @ Mar. 01 2006,14:04)]That is a great write up. Thanks Bill. But you gota explain to us mecanical rookies like me what hooking the vacuum hoses like that will do? Sorry I question if it will do anything but give the vacuum sensor a weak signal.
Hey Kev...I only hooked'em up like that cause I hadta cut off my stock hoses as they were cooked onto the nipples and was in a rush...then thought about the very same "weak vacume sig" you just mentioned and I went back to the stock config 4 way X-over...but seat of the pants couldn't tell any dif...no biggy either way....done this sorta thing before on none FI'ed bikes I've owned...btw...the stock hose is 4mm (.160") ID..I replaced it all with 5/32ths...(.156")...again no biggy....just a tighter fit/seal and available at most auto parts stores.
L8R, Bill.
  #38 (permalink)
Old 03-01-2006, 09:59 PM
loboboy's Avatar
Default
I have a question, how did you get your bike to start without the IAP air press sensor hooked up? I can never get mine to start without it hooked up.
They call me TATER SALAD!!!!!!!!!
  #39 (permalink)
Old 03-01-2006, 10:45 PM
DAB DAB is offline
Hayabusa Immortal
Group: Members
Default
Good Job Jinkster.
  #40 (permalink)
Old 03-02-2006, 09:31 AM
Default
Hey Bill, I think I want to hire you as my full-time mechanic. What do you say? * *
"Get me a juice box beaotch"
2005 Red/Black
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
(c) 1999-2009 Hayabusa Owners Group
