Go Back   Hayabusa.oRg > Technical > Maintenance and Do-It-Yourself
Reply
LinkBack Thread Tools Display Modes
  #21 (permalink)
Old 12-14-2005, 04:42 PM
Never Forgotten
Group: Never Forgotten
Default
530 ZZZ
  #22 (permalink)
Old 12-14-2005, 04:53 PM
Jester0769's Avatar
Hayabusa Master
Group: Donating Member
Default
tsubaki 530 10,800 tensil.
Been good to me. I kinda like it, just wish it was gold
______________________________________
I am a member of a maverick cult on the verge of respectable motorcycling.......
"If Milli Vanilli fell in the woods, would someone else make a sound?"
There is no right or wrong, just fun and boring.
  #23 (permalink)
Old 01-05-2008, 05:47 PM
Mr Bogus's Avatar
Trouble Makers Inc.
Default
I am looking for the "installed" width on the rivet style master link.. (how much crimp to put on the pin) I have blown rivet style master links in the past and do not want to do it now Not sure the motion pro crimper will do that, but I want to go riding monday and if I screw this up, I am SOL.... thanks in advance
Oh yea... EK530ZZZ chain
Made in Germany, you know those Germans always make good stuff... "Vince"
  #24 (permalink)
Old 01-05-2008, 07:05 PM
Warchild's Avatar
Top Gun
Group: Members
Default
Looking for the width of the "flare" of the staked rivet, yes?
If so... for the RK chain, this is 5.55mm-5.95mm.
  #25 (permalink)
Old 01-05-2008, 07:10 PM
Mr Bogus's Avatar
Trouble Makers Inc.
Default
Thanks for the reply WC..
Was not sure if they were going to measure the "width" of the rivet or the "length" of the rivet for install specs. RK measures the diameter of the rivet, wonder if EK is going to do the same?
  #26 (permalink)
Old 01-05-2008, 09:36 PM
Warchild's Avatar
Top Gun
Group: Members
Default
The K8 Service Manual provides both specs, interestingly enough.
On page 3A-9 of the Service manual, the specification range for what they term as "Joint plate dimensions" (which are the outside edges of the side plates, once pressed into place) is 22.25 - 22.55mm
Page 3A-10 has the spec and picture of the master link staked pin "flare" of 5.55 - 5.95mm.
Dunno if it's a critical issue, but this is for the stock RK "GB50GSVZ4" chain that is OEM for the K8.
Not sure how much I like this chain so far.... the first 400 miles, I had to adjust the chain twice. Prolly just normal break-in stretching. Maybe.
When I dismounted the BT-015 at 500 miles and mounted the PPs and adjusted the chain, it seems to be holding it's adjustment just fine. I'm at about 1200 miles now, adjustment seems to be holding steady at ~ 25mm, so....
  #27 (permalink)
Old 01-06-2008, 01:28 AM
Mr Bogus's Avatar
Trouble Makers Inc.
Default
I got about 13K out of the OE chain and it developed a kink and was riding up in the sprockets (gives a sensation of an engine surge, quite un-nerving)
I went with the best thing I could get in the EK line which is the EK 530ZZZ chain. They do not have posted on their site the rivet swedge or pin length posted for the master links on their site but emailed them to see if I could get it.. Likely not a big deal as long as the pins are mashed out by the tool. But I did have a previous master link pin crack and break during the staking process and it was either due to brittle material or I just got carried away..
since then I just compress the rivet to spec and forget about it
  #28 (permalink)
Old 08-03-2008, 11:17 AM
KAI KAI is offline
Seasoned Pilot
Group: Members
Default
I have 800 miles on my bike and it seems to me that the chain needs to be adjusted. On the top part where the chain is, theres this little 'rail' thats part of the swing arm where the chain rests on with the bike off and on the stands. Seems like that was made specifically for the chain but wasn't sure if it was supposed to sit on it like that.
In the manual, it says it should have .8 - 1.2in of slack but how do I measure that? With the chain rested, push it all the way up and check? Or do I push it up and down and check the total movement from that?
http://img300.imageshack.us/my.php?image=christbikevb7.jpg
  #29 (permalink)
Old 08-03-2008, 09:33 PM
Supergank1's Avatar
Professional Pilot
Group: Members
Default
sprocketcenter.com
2007 Blue Busa w/Brocks Gen2 System,PC3,TRE,airbox mod..
2001 GSXR1000.Modded up Â*
  #30 (permalink)
Old 08-03-2008, 09:37 PM
BlueHaya's Avatar
I'm outta here!!!!
Default
I just push mine up and down and look for about an inch of total travel.
"Don't taze me Bro!!"
"In God We Trust"
"It takes 43 muscles to frown, 17 to smile, but only 3 to perfectly squeeze the trigger"
  #31 (permalink)
Old 05-19-2009, 07:23 PM
bpjones's Avatar
Rookie
Group: Members
Default Re: Good Chain Websites... Need a new Chain? Cleaning?
Well, it's time for a new chain and sprocket for the 99.....
Any consensus on what most people are riding?
What's the hype about going up to a 43 tooth sprocket?
Is it standard to change out the front and rear sprocket at the same time?
Loking for brand/item and price recomendations here.....
2003 Black/Silver Hayabusa
Gear Indicator, Speedohealer and
Beltronics Vector 995 with Peizo Speaker
Sold: 1999 Copper/Silver
  #32 (permalink)
Old 06-19-2009, 09:36 PM
Professional Pilot
Default
I need a new chain and also thinking about going with 43 rear. Eagerly awaiting wise responses.
Posted via Mobile Device
  #33 (permalink)
Old 07-15-2009, 09:40 PM
Rookie
Group: Members
Nearing 10K on my 07 and also looking for suggestions on just going with a chain like the 530zzz or both sprockets and chain.
BTW havent had any issues with the stock yet so can I get more miles out of it? The sprockets look great still!
  #34 (permalink)
Old 07-15-2009, 10:21 PM
acehole's Avatar
Hayabusa Master
Group: Super Moderators
The chain cleaning link shows the guy using a hair drier to warm up the chain. I use a heat gun and warm the chain as i rotate it. This also gives me the time to inspect chain for anything out of line. I live on a dusty road, so warming by riding is a no no. Anyway, the hair drier thing works Great!
"Does this bike make my BUTT look BIG!?!?"
"I have NO Shame"
  #35 (permalink)
Old 07-15-2009, 11:03 PM
GoldenChild's Avatar
DID HE REALLY SAY THAT?
Group: Site Sponsor
give me a call we'll talk...
  #36 (permalink)
Old 07-16-2009, 12:53 PM
Hayabusa Legend
Group: Site Sponsor
We are always running sales on zzz chains and sprockets. let me know what you are looking for.
Thank you,
Charles
email info@streetntrackimport.com
paypal Sales@streetntrackimport.com
913-788-4281
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
(c) 1999-2009 Hayabusa Owners Group
