Go Back   Hayabusa.oRg > Technical > Maintenance and Do-It-Yourself
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 10-14-2009, 12:10 PM
Seasoned Pilot
Group: Members
Default Spark Plug Change - Did I do something wrong?
I changed the plugs on my '04 last weekend and I'm concerned that I ignored one of the plug removal instructions that I ran across after the fact this week: "Now disconnect the lead wire from each plug cap/ignition coil and the camshaft position sensor." Instead I just wiggled the 5 inch plug coil free and removed the plug.
There was also this warning: "There are certain points that you should remember when servicing your spark plug
a) Never remove the plug cap/ignition coil before you disconnect all its lead wire couplers"
I don't know what this means and of course I didn't do it. Did I screw the plug change up? If so, what is the remedy? And if any of you have pics of what's being talked about, please reply with them.
  #2 (permalink)
Old 10-14-2009, 12:17 PM
mike1180's Avatar
F.O.G. HOON
Group: Donating Member
Default Re: Spark Plug Change - Did I do something wrong?
If it runs OK now it is fine.
The warning is so you don't damage the coil connector.
______________________________________
I have tried, in my way, to be free.
2006 LE "Magic Carpet Ride"
  #3 (permalink)
Old 10-14-2009, 12:25 PM
Commuta_Busa's Avatar
Hayabusa Immortal
Enemy Shooting Champion
Group: Members
yea, as long as you didn't rip any wires out of the connectors you're fine. Did you put a dab of anti-seize on your plug threads? <- that's my only tip.
2009 Super Streetbike's Top Speed Challenge Winner
Unlimited naturally aspirated class
  #4 (permalink)
Old 10-14-2009, 02:20 PM
dadofthree's Avatar
Seasoned Beef
Changed 4 sets out of the '06 just like you did. No problems.
Robert 44,000 plus post
  #5 (permalink)
Old 10-14-2009, 02:30 PM
BA BUSA's Avatar
MotoGP Wannabe
Anime BlackJack Champion
The warning is so you do not damage any of the wire connections or the harness...if it runs good...your good to go
  #6 (permalink)
Old 10-14-2009, 04:15 PM
Seasoned Pilot
Group: Members
Thanks guys. I was very gentle as I lifted and reconnected the coils, and yes I did apply anti-seize to the spark plug threads. But the bike isn't running properly. It bogs down (stumbles) at low rpm's when I wank the throttle. I haven't had a chance to test the problem that got me to change the plugs in the first place: missing at very high rpm's. I need a stretch of freeway for that.
  #7 (permalink)
Old 11-12-2009, 04:44 AM
suzuka1980's Avatar
Seasoned Pilot
Group: Members
i did the same thing as you. Plucked it right out. Does not damage anything...no worries
  #8 (permalink)
Old 11-12-2009, 04:50 AM
B@DA$$08BUS@'s Avatar
Hayabusa Master
Was the spark plug gap accurate?
Posted via Mobile Device
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Spark plug????? 00busaMan Busa problems 15 07-17-2009 01:02 PM
spark plug # Ban-One General Bike Related Topics 4 03-14-2009 01:33 AM
what's the best spark plug to use? eaglebusa Engine and Performance mods 22 06-08-2008 03:51 PM
Spark plug change jaschil69 General Bike Related Topics 2 06-02-2006 01:02 PM
Spark Plug tocullo Engine and Performance mods 6 01-28-2006 10:47 AM
(c) 1999-2010 Hayabusa Owners Group
