You want believe this one (maybe you will), I had my rear plastics off tonight and when I put everything back together I forgot to hook up the lock cable. Well I Put the hump back on with no cable....DUH!!!! Now I turn the key, no unlocky the humpy. How do I get this freakin thing off without cutting a hole in it? Any suggestions? HELP? |
Lofty, with a little bit of luck, you might be able to do it by removing the tail light. If the cable is near the cable harness hole, you might be able to wiggle it thru the hole and just pull the wire. Use a metal clothes hanger. Good luck! |
| Quote:
______________________________________ |
| Quote:
"Just walk away. Find something else to do. Because the life you save may be your own!" * * * -- Double A |
It's happened a lot so don't worry. Do a search, the question has been asked many times.
You gave your live to be the person you are today. Was it worth it? |
| Quote:
I was only 35 when that post was made. I don't even remember what I was doing back then.
| Thread Tools | |
| Display Modes | |
