Page 1 of 2 1 2 LastLast
Results 1 to 20 of 22
  1. #1
    Join Date
    Nov 2008
    Posts
    Default 2003 Hayabusa wont start HELP!!!
    I just purchased my first busa... I rode it yesterday..Started it this morning.
    and turned it off before it could warm up.. Now it wont start.. I ran the battery down so I jumped it and it came up with a f1 code.. I did the Ghetto dealer switch and came up with code c-11... PLEASE help a newbie.!!!!!!
    Thanks,
    Matt
  2. #2
    Wag
    Wag is offline
    Evil Demon Busa Rider
    Wag's Avatar
    Join Date
    Aug 2004
    Location
    Rio Rancho, NM
    Posts
    9,814
    Default Re: 2003 Hayabusa wont start HELP!!!
    Does it crank or try to crank when you press the button? Does the light dim?
    A tad more detailed info would help us help you.
    I have an '03 too but anyone with a Gen 1 can help ya.
    --Wag--
    "Morality is doing what is right no matter what you are told. Religion is doing what you are told no matter what is right. " -- Unknown
  3. #3
    Hayabusa Immortal
    99'busa's Avatar
    Join Date
    Dec 2007
    Location
    Indianapolis
    Posts
    15,523
    Images
    im with wag. here. more details. dont know what that code is without the book.
    Grip it and rip it!
  4. #4
    Seasoned Pilot
    Join Date
    May 2003
    Location
    rock hill sc
    Posts
    404
    The shop manual is on here some where, download that and you can look up the codes, its been a lifesaver for me over the years. I keep mine on a disc and on the desktop. It is the bible, so it is written, so shall it be done...
    99 Busa Black/Grey Bought brand new *Stolen June 14 2007*
    Muzzy 4-1, Air box mod, K&N filter, Remapped F/I
    03 Busa Grey/Black
    cerebusa,hound from hell,,,its better to burn out, than to fade away.....
  5. #5
    tjdobb's Avatar
    Join Date
    Apr 2006
    Location
    Wisconsin
    Posts
    513
    C-11 The manual says to check the camshaft position sensor or circuit malfunction.
    2011 White
    V & H header with 2 bros exhaust
  6. #6
    Hayabusa Immortal
    shawnski's Avatar
    Join Date
    Mar 2008
    Location
    houston,tx
    Posts
    2,984
    Images
    are you holding the clutch when you crank, did you try it with kickstand up or down sitting on the bike? DOES IT CRANK ?
    try to have someone push the bike while you sit on it and release the clutch in second gear see that would start it up.
  7. #7
    Member of P.E.A.
    twotonevert's Avatar
    Join Date
    Aug 2007
    Location
    Tehachapi CA
    Posts
    26,008
    Images
    27
    Welcome to the board. If it ran fine yesterday, disconnect the battery cable and leave it off for a few minutes. Reconnect and see if you have same problem.
    Do you know God? http://www.lifechurch.tv/
    Its a Jeep thing, you wouldnt understand!
  8. #8
    Join Date
    Nov 2008
    Posts
    The bike turns over fine there is no code until I try too jump it. Then the code pops up. I here the fuel pump running. I pulled the plugs and cleaned them. Im going to take the battery out and charge it now.
    Thanks for all the response already.
  9. #9
    Banned
    Join Date
    Dec 2006
    Location
    Alberta, Canada
    Posts
    5,706
    To my knowlegde the injectors won't work unless the battery is fully charged.
    I would take the time and charge it up fully, as you did drain it down to nothing.
    I can't see cam sensors going bad just because you ran the battery down.
    JMO
  10. #10
    Professional Pilot J.Busa's Avatar
    Join Date
    Sep 2006
    Location
    The N. edge of Texas
    Posts
    734
    What are you jumpstarting it off of? Not a running vehicle or a jumpbox I hope.
    02 Silv/Grey -45,000+ miles and counting
    Does this rag smell like Chloroform to you
  11. #11
    Banned
    Join Date
    Oct 2004
    Location
    Seattle Area
    Posts
    8,213
    Images
    31
    The bike won't fire until it has 12.4-12.6 VDC while cranking. How are you jump starting it? If you are using another vehicle I hope it isn't running. A running car or truck can spike up to 14.8 VDC when it sees the additional load from the bike's battery. That is too much voltage for the ECU of the bike. Leave the bike on a charger or connected to the battery of a car and lit it charge for about 30 minutes. Then you should be able to start it back up.
    If the C11 code comes on you will want to disconnect the battery ground, and turn the key to run. Leave it like that for a few minutes. Turn the key off and reconnect the battery ground. Try to start it again. If you still get C11 you may have a loose connection somewhere.
    The clitch lever will need to be pulled, and the side stand will need to be up or trans in neutral or the starter won't get power.
    NickSlick has a download link for the service manual that was posted a while ago. I'll see if I can find it.
  12. #12
    Banned
    Join Date
    Oct 2004
    Location
    Seattle Area
    Posts
    8,213
    Images
    31
  13. #13
    Head Woodchuck
    TIMMYDUCK's Avatar
    Join Date
    Feb 2003
    Location
    The 14Th State ---- VERMONT
    Posts
    3,976
    When you shut it down did you lock the steering stem ?
    If you did you might have gone to far with the key and left your parking light on, thus draining your battery.
  14. #14
    Join Date
    Nov 2008
    Posts
    Ok I found my problem with the cam position sensor.(it wasnt snapped all the way in) I snapped it in and tryed to start it. It fired probably five times. And wouldnt start. Now it wont fire. It still turns over fine and I can smell the gas and hear the fuel pump. Could the plugs be fouled out? The bike has 5200 mi.
    Can you use starting fluid? I dont want to try that until i have to.
  15. #15
    Wag
    Wag is offline
    Wag's Avatar
    Join Date
    Aug 2004
    Location
    Rio Rancho, NM
    Posts
    9,814
    I don't like starter fluid on an injected bike. Don't know why, it just makes me a bit uncomfortable for some reason.
    I think you can foul the plugs. I suppose you could pull 'em and let 'em air out a bit.
    --Wag--
  16. #16
    Hayabusa Legend
    Big Red's Avatar
    Join Date
    Apr 2005
    Location
    Irving Texas
    Posts
    2,191
    Images
    25
    Sounds like you fowled the plugs
    No one has ever convinced me that this is not paradice.
  17. #17
    Top Gun Supergank1's Avatar
    Join Date
    Dec 2007
    Location
    Brooklyn,NY
    Posts
    1,074
    Images
    change the plugs and fully charge the battery and it should be good..now that u plugged the cam sensor back in.
    2007 Blue Busa w/Brocks Gen2 System,PC3,TRE,airbox mod..
    2001 GSXR1000.Modded up *
  18. #18
    Poppy's Avatar
    Join Date
    Aug 2005
    Location
    Relocated out west
    Posts
    4,018
    Kill switch position is.........?
  19. #19
    New Recruit
    Join Date
    Mar 2011
    Posts
    51
    curious, did u figure out what was the fix?
  20. #20
    GIXERHP's Avatar
    Join Date
    Jan 2003
    Location
    NASHUA NH
    Posts
    13,427
    Images
    Ahem,, 3 year old post!
    Quote Originally Posted by Bertactive View Post
    2013 LIMITED, Little Yellow Short Bus!
    04 LIMITED BUSA, 1397 kit, intake cam swap, 50hp wet NOS kit!
Similar Threads
  1. Wont start
    By RdRcr150 in forum Busa problems
    Last Post: 03-16-2009, 04:22 AM
  2. Help! wont start...
    By SNakez9 in forum Busa problems
    Last Post: 08-29-2008, 11:22 AM
  3. Bike will start then wont start
    By boosted in forum Turbo
    Last Post: 07-03-2008, 10:36 PM
  4. wont start, please help!
    By big ed in forum Busa problems
    Last Post: 05-07-2008, 09:34 AM
  5. It wont start!!!
    By solway19 in forum Busa problems
    Last Post: 01-24-2006, 03:15 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
