NCpanther01
Need HELP!! I installed a new rearset! And I'm having problems shifting gears. Can anyone assist?
i had the same prob i rode it then i couldn't shift past second after i let it sit for awhile and then rode and it wouldn't shift it ended up being air in the clutch lines... just a tip but might not be itNeed HELP!! I installed a new rearset! And I'm having problems shifting gears. Can anyone assist?
Don't cut anything.Follow up! Roc and I switched the rods and it worked great for awhile then I couldn't shift again pass 2nd!!! The long rod was to long and the medium on wouldn't work for long. So I'm thinking on cutting down the longest rod between the medium and the lonest one. Stay tuned and thanks for the feedback from all!!!!
That would be a good start. Grease it up and also and check your fluid level in the master cylinder.I think it may be the clutch slave is not aligned!!!!
Yup. Yup. ...and Yup.I would doubt clutch cause even with no clutch you can shift the bike with a blip of the throttle
