Hi,can anyone tell me what this part contains (pn.99500-39183-03E),it'sto repair the starter gear in the 1999-2002 busa's..I called several Suzuki dealer's,and they said pt.# is good,price is between $75-$82,but they couldn't give me part description ...need to know what I'm spending $80on THX
That would be just for the gear. Â*Most likely you will need the starter clutch if it is not starting or just spining. Â*The whole unit is about 128.00. Â*If you do the gear you will als need a new gasket. Oh and look under the repair manual on this site. Â*You should be able to see all the parts numbers. http://www.hayabusa.org/forums/?act=ST;f=24;t=29016 |
| Quote:
first time I experienced that noise in 8 years,since then I've started bike up many times,and it seems to be normal THX
| Quote:
This problem was first found on big displacement high compression drag bikes when the engine would kick back with enough force to cause the starter clutch to slip. When it would catch in the middle of a kick-back, starter related gears and/or the engine case would break. I believe Suzuki had a bad batch of starter clutch assys. in late 2001 and 2002. My 2002 was stock when it began to have starter clutch problems. I eliminated kick-back as a cause when I disconnected the coils and hit the starter button. It still popped. I replaced the starter clutch and had no problems until she was stolen. For the 2003 model year and newer, Suzuki beefed up the starter clutch assy., idler gears, and added a back torque limiting mechanism to one of the starter gears. You could upgrade to the '03 and up starter mechanism, but that is expensive because everything from the starter to the starter clutch has to be changed. For information about this problem read: this thread I notice the post dates in that thread are messed up. It lists my posts after my Tetsuko was stolen, which was not the case. Weird. Karl ______________________________________
2002 Black/Blue- stolen 05-13-2005 2003 AE Throttlemiester, heavy polished Helibars, filled with #9 lead shot Juggler mirror spacers Scorpio SR-i500 McCulloch 5k HID low beam from XenonKing Avon Viper Sports from Ryders Connection Woodcraft engine cover from GIXERHP |
| Thread Tools | |
| Display Modes | |
