I'm no tech. here or anything but I found this in the service manual that I downloaded from here. Try checking the speedometer sensor? or any connections dealing with it maybe. Heres a quick snapshot. goodluck with it
Ted, is this the same bike that you went down on? After I dumped my bike, all my gauges we never the same! They all screw with me now. One works one day and then the next it is something different....
that happend to my bike,I took the nose off 2x checked all connections,everything was tight,,said F-it,then a day later it was working,to this day I dont know what caused it
This just happened to me when I got my bike put back together with the custom paint job. I took it back to the mechanic and he just unpluged the gauge and plugged back in and it started working again and it is still working since he did that. He said it was just a fluck......
I saw your post about that and was wondering what came out that situation. I took the sprocket cover off and cleaned all up behind the cover. I also took the nose off and tried reconnecting it. I'll try the sensor first and if that doesn't fix the problem then I guess I'll have to get a new speedo. Thanks everyone and you all have a great Holiday.
