Results 1 to 12 of 12
  1. #1
    Top Gun
    Join Date
    Sep 2004
    Location
    Phoenix, Arizona
    Posts
    1,377
    Default
    so a while back when i added the ext swing arm to my bike, and then tried to get the tire on.. well, it was pretty much a huge pain in the butt because the rear wheel would be up against the handle and id have to "juggle" the swingarm to get the tire in there. so i was wondering what yall with ext swing arms are doing/using. i thought about getting a rear stand and cutting the bottom/sides and welding a 4" tube. so basically its 4 inchs longer and this was it will "work" anyone tried this?
    2001 Hayabusa
    lowered 1 front, 2 rear, M4 exhaust, Ti header/ CF muffler & PCII, +6 Catalyst fiberglass tail, +6 swing arm, '99 Alum. Subframe, Alum. Triple Tree, C/F front fender / chain guard / inner panels / mirrors, AirTech Slammed fiberglass tank, Vortex -1 +2 sprockets, EK 530ZZZ gold chain, air shifter, PUIG smoke DB, BMC Race Filter, Galfer S/S lines, APE Clutch, APE HD springs, 1 piece clutch hub, Clear Clutch cover, APE cam chain tensioner, Shinko R003 120/70 & 200/50, next..cams
  2. #2
    thebbbusa's Avatar
    Join Date
    Feb 2005
    Location
    Westerville, OH
    Posts
    1,937
    Default
    my stand uses paddle like feet that lift using the swingarm or extensions instead of spools. Some
  3. #3
    Seasoned Pilot big coop's Avatar
    Join Date
    Jul 2007
    Location
    South Florida
    Posts
    451
    Default
    Motoboss stands.
    BigCoop
  4. #4
    Seasoned Pilot Hot Rod Harv's Avatar
    Join Date
    Dec 2007
    Location
    St, Louis Mo.
    Posts
    307
    Default
    I have an extended swingarm and I got the $89.95 (plus S&H) for BOTH stands deal from www.flyncycle.com
    They work fine.
    Attached Images Attached Images
    2004 Black/Purple (the fastest color)
    With Big Bird 4-2-1,
    Pair removed,
    Air box mods,
    Factory Pro V-Stax, Velocity Stacks
    K&N Air Filter
    Polished frame,
    0-6" polished TCC swing arm,
    Lowered 1&1/2" both ends,
    Vortex rear sets,
    Drilled rear brake bar,
    Under tail section,
    MPS Air shift/on board compressor,
    Zero gravity windshield,
    Hayabusa emblem seat,
    Barnett Clutch with Total Chaos Billet Cover,
    "Carbon Fiber" Tank bra,
    Heli bars,
    Billet top tree chromed,
    Video Camera Tank Mount
    MAP by Jessie Gatlin Racing ( St Louis Mo.)
  5. #5
    Top Gun
    Join Date
    Sep 2004
    Location
    Phoenix, Arizona
    Posts
    1,377
    Default
    Quote Originally Posted by Hot Rod Harv @ Apr. 19 2008, 7:02 AM
    They work fine.
    those look like they would work alot better then the others i have seen. most have the handle go at like a45* angle where those are lower. ill have to get those
    2001 Hayabusa
  6. #6
    Join Date
    Dec 2007
    Location
    St, Louis Mo.
    Posts
    307
    Default
    Quote Originally Posted by AZIROC @ Apr. 19 2008, 11:20 AM
    They work fine.
    They are great, just put a drop of oil on the pin when you put them together so it will rotate smoothly when you raise it.
    Don't forget to put your kickstand down, BEFORE you take your bike off of them....
    They make oiling your chain a breeze too.
    You will like them, they are very sturdy.
    Pair removed,
    Air box mods,
    K&N Air Filter
    Polished frame,
    Vortex rear sets,
    Under tail section,
    Heli bars,
  7. #7
    Canuck Ground Pilot
    _WOLFMAN_'s Avatar
    Join Date
    Jan 2007
    Location
    Alberta, Canada
    Posts
    669
    Default
    This is the stand I will be ordering to go with my Canadian Mike 0-6" Stretched 600 Arm in May.
    http://www.pit-bull.com/Merchan...._stands
    04 Hayabusa, Tsukigi Exhaust, Tobin Seat, Powerbronze Screen, Powercommander, Catalyst Undertail, CM Swingarm, Traxxion AK-20, Penske 8983, Carrozzeria Wheels, Revolution Rotors, Galfer Lines and Pads, Spencer Cycle Top Clamp, Adjustable Kickstand and Billet Rear Caliper Hanger
  8. #8
    Top Gun
    Join Date
    Sep 2004
    Location
    Phoenix, Arizona
    Posts
    1,377
    Default
    Hmmmm
    2001 Hayabusa
  9. #9
    thebbbusa's Avatar
    Join Date
    Feb 2005
    Location
    Westerville, OH
    Posts
    1,937
    Default
    Quote Originally Posted by _WOLFMAN_ @ Apr. 19 2008, 5:45 PM
    As long as your arm has spools....
  10. #10
    Join Date
    Dec 2007
    Location
    St, Louis Mo.
    Posts
    307
    Default
    Quote Originally Posted by Hot Rod Harv @ Apr. 19 2008, 2:48 PM
    They work fine.
    I just changed the front tire and the axle bolt was tight; no problem taking it off, or putting it back on, they worked like a dream.
    It's back together now and ready to hit the streets.
    I like the dual wheels, they automatically balance the arm out, and do not try to twist or anything, like a single wheel might.
    The price is good too, $89.95 for BOTH, I have seen higher prices for just one.
    On a side note; I had to make a tool to take the axle apart. I used a 5/8" bolt and nut, which has a 15/16" head.(that happens to be the same size of the hex "hole" in the axle)
    I welded the nut to the bolt and insert the bolt head into the hex end of the axle. I use a 15/16" socket on the nut and it works so easy.
    Pair removed,
    Air box mods,
    K&N Air Filter
    Polished frame,
    Vortex rear sets,
    Under tail section,
    Heli bars,
  11. #11
    Seasoned Pilot
    Join Date
    Dec 2006
    Location
    Senatobia, MS
    Posts
    412
    Default
    Sorry I didn't see this thread sooner. We cover this for you guys...
    Ian
    http://redlinestands.com/wideswingarms.htm
  12. #12
    Professional Pilot woodwheel's Avatar
    Join Date
    Jan 2008
    Location
    Northern VA
    Posts
    677
    Default
    Quote Originally Posted by RedlineStands @ Apr. 23 2008, 7:20 PM
    Sorry I didn't see this thread sooner. *We cover this for you guys...
    Ian
    Do you have any stands that fit a 300 without spools?
    07 GSXR 750
    07 GSXR 1000
    08 HAYABUSA
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
