Page 3 of 3 FirstFirst 123
Results 41 to 53 of 53
  1. #41
    Never Forgotten vman1300's Avatar
    Join Date
    Feb 2000
    Location
    99 miles from Deals Gap
    Posts
    10,437
    Default
    Quote Originally Posted by Mr Bogus @ Jan. 24 2008, 10:16 PM
    Still does not fix the boiling fluid issues that a rider like Vman can generate but then again, you must look at his service schedule... I bet he does not fudge on it either..
    I throw away brakes that could still be used, just due to my riding style. Along with fluid, they are inexpensive and easy to change. I see people spend many bucks on modifications but not spend chump change on a miti-vac and fresh fluid.
    Is changing fluid after every Gap trip or a track day necessary? Even for me, probably not but it is cheap insurance.
    "In our darkest hour...we look to the sky. With a silent prayer...BELIEVE God's on our side. In the land where FREEDOM reigns...and where eagles fly."
  2. #42
    Hayabusa Master dolilind's Avatar
    Join Date
    Jul 2007
    Location
    Bowie, Md
    Posts
    1,755
    Default
    Ok after reading all this, what is the real advantage from the dot 5? Other than safe on paint a boiling points? Any actual peformance advantages, such as stiffer feel? more pressure? Or just benifit from higher boiling temps? Much easier on the wallet $2.50 pint to $12 a pint.
  3. #43
    Join Date
    Feb 2000
    Location
    Posts
    10,437
    Default
    The main reason I changed, again to DOT 5.1, was brake fade on trackdays. Higher boiling point was the reason.
  4. #44
    Join Date
    Jul 2007
    Location
    Bowie, Md
    Posts
    1,755
    Default
    so what are ya saying, im wasting some $$ that could be used other places by swtiching over to the dot5? i get the galfer pads rotors, and goodrich lines.
  5. #45
    Join Date
    Feb 2000
    Location
    Posts
    10,437
    Default
    Quote Originally Posted by dolilind @ Jan. 25 2008, 11:04 PM
    Remember, we are talking about different fluid.
    DOT 3 and 4 are compatiable with DOT 5.1.
    DOT 5 is NOT compatible with 3,4,or 5.1. Lots must be changed that have been covered in earlier posts, IE all rubber parts that have been exposed to 3/4/5.1.
    The reason to switch to 5.1 is the higher point if you are experiencing brake fade. The Busa is a heavy bike and when ridden hard on the track, brake fade is an issue.
    If you have lines, pads and rotors and are needing a better brake feel, make a switch to a Brembo master.
  6. #46
    Supercharged's Avatar
    Join Date
    Nov 2007
    Location
    New Jersey
    Posts
    37
    Default
    To try and clear things up... DO NOT CHANGE OVER TO DOT 5.
    If you are roadracing, carry a heavy payload, or for whatever reason are boiling you stock fluid. Spend your money on castrol srf about $80usd/litre.
    It is second to none! Formula one and moto gp use it.
    Going down in rank would be afco, ap racing, and motul600.
  7. #47
    Enjoying 1 road at a time
    raydog's Avatar
    Join Date
    Sep 2006
    Location
    Reno, Nevada
    Posts
    4,325
    Default
    Hey Vman, I run Braking rotors, Vesra pads, SS line....can I retrofit a Brembo master cylinder and still use my Pazzo levers? I guess the real question is...with Brembo, must I go to a different Brembo lever or would an OEM Busa lever fit (therefore my Pazzo Busa lever would also fit). Raydog
    2000 HayBus..track bike, sport touring. Full Race Tech Suspension, PC III, Corbin, Sato rearsets, Matris damper, carbon fender, Carbon Muzzy, HID lighting, billet countershaft cover, Woodcraft, Pazzos, 0-6" arm, full Autocomm electronics, Heli, Beltronics, Zumo, etc.
    2005 Busa naked Superbyke..Accossato radial brake master cylinder, Steigler superbike handlebar conversion, Race Tech springs, Matris damper, Pazzos, Carrozzeria wheels, Braking rotors, Tobin, Oberon barend mirrors, M-4 exhaust, carbon fender, Hotbodies tail, Kellerman turnsignals, much more, still under construction.
  8. #48
    Join Date
    Feb 2000
    Location
    Posts
    10,437
    Default
    Quote Originally Posted by raydog @ Jan. 26 2008, 12:21 AM
    Hey Vman, I run Braking rotors, Vesra pads, SS line....can I retrofit a Brembo master cylinder and still use my Pazzo levers? Raydog
    Nope, the Brembo uses a different lever...
    Pazzo make a lever but the adjustment is different.
  9. #49
    raydog's Avatar
    Join Date
    Sep 2006
    Location
    Reno, Nevada
    Posts
    4,325
    Default
    Thanks for the fast answer! OK I could buy another Pazzo for the "feel" I love...with the Brembo unit....do you sell that stuff?
  10. #50
    Join Date
    Feb 2000
    Location
    Posts
    10,437
    Default
    Quote Originally Posted by raydog @ Jan. 26 2008, 12:29 AM
    Yes we do, and it is more than just a master....
    Brembo install
    Let me know if I can help.
  11. #51
    raydog's Avatar
    Join Date
    Sep 2006
    Location
    Reno, Nevada
    Posts
    4,325
    Default
    Thanks again Vman, I ride hard in the twisties (with all them younger Nor Cal fellas) with occasional track days, weigh 240+ and think your conversion would be perfect. I'm saving this strand and right after I get a HD flatscreen (just got permission from my boss)I'll PM you (like after taxes). Have to do the flatscreen first though...with Qatar doing the first MotoGP in HD AT NIGHT! Take care, Raydog
  12. #52
    Join Date
    Jul 2007
    Location
    Bowie, Md
    Posts
    1,755
    Default
    Thanks for the info. Im installing all new break system today, and i guess i better send back the dot 5 fluid the bike shop sold me. And since im not track riding guess i will stay with old reliable dot 4.
    Thanks again for the info.
  13. #53
    Join Date
    Nov 2007
    Location
    New Jersey
    Posts
    37
    Default
    Very good to hear that!
    Be safe!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
