The wheel holds slotted rubber blocks. The hub has tabs that go into the slots in the rubber blocks. This provides a cushion between the wheel and the drive train.
______________________________________ |
The sprocket goes over top of the area and slides into the rubber pieces (cush rubbers) ______________________________________
Greg "Obstacles are those frightful things you can see when you take your eyes off your goal." - Henry Ford |
once together the cush rubbers "cushion" the torque from the chain to the rear wheel making for smoother shifts and take offs.
The cush rubbers are there so when you get a little slop in em, the wheel hub falls off every time you pull the rear wheel. Suzuki designed them to help build character in less mature riders. ______________________________________ |
Nice explanation. Thanks! So how do you know if they wear out? A visual inspection looking for cracks? It doesn't really look like they deteriorate.
I just want to look pretty, not actually be pretty.
Look at the picture in post 4. There are two sets of Cush rubbers there. The top ones are brand new - the bottom ones are worn out - notice the marks in them? ______________________________________
'04 Blue/Silver
What's the recomended interval for changing them? Is there a recomended mileage? I think I changed mine out somewhere around 20,000 miles.
SPORTBIKES.NET 2003 40th Anniversary Edition Hayabusa |
Busa Bill......GOOD ONE..."character building".........works for me. As far as replacement. *You'll start noticing a bit *of a pause/gap (very small) between acceleration torque, and downshift drag (engine braking). *Almost feels like chain slop. *It's so minute, that you might miss it for some time. *I was noticing I've got about an 1/8"-1/4" of free rotation between the rear wheel fore and aft grab (link engagement). *Did this on a rear stand by the way. "I believe it's time". * Get your rear end in the air, roll your wheel back and forth, forward, then gently backward. If all you get is tension from the chain, you're good. *If you have failing cush rubbers, there will be an independent shift between the rear sprocket hub, and the wheel center. *Like the chain and sprocket aren't moving, but you can still get the tire to roll a wee bit. *With as many foot pounds of torque as even a stock "un-modded" Hayabusa puts out, they get mashed, start to compress, and eventually fail. *Although they won't fall out on you while you're driving. *In this case, "Snug is good". * By the way "Heavy"...NICE PICS !!!! ______________________________________ Spudley, 05' R/B, "RUBBER SIDE DOWN ALL THE TIME, AND ALWAYS BRING YOUR A-GAME !!!". Amsoil Synthetics / Race Ready Painted Inner Panels / Bagster Tank Protector & Tank Bags / Hump Mod / ZG Double Bubble / Mirror Spacers / Custom Fairing Grills / Fast idle mod / +1" dogbones / EK ZZZ 530 / Michelin HPX's / TL 1000R Pegs / EBC HH Pads / 3/4" Risers / GPS Mod / Speedohealer V.4.0 / Galfer SS Lines / R1 Throttle |
| ______________________________________ ZeroGravity Sport/Touring Windscreen - Harris 'Busa Grips - TL1000 Pegs - Tobin Seat - Devil High Mount System - Clear Alternitives Smoke Intergrated Tail Light - Ram Mount Stem Mount for GPS/MP3 Player - Black/Carbon Look Tank Bra - RoadLok -30 LED Switchbacks - Black Outlaw Racing Gear Lever & Rear Brake Lever |
Nice writeup. I was wondering what the hell a cush drive was.
______________________________________ Project Great White: 2000 White F350 4wd, CrewCab, Dually, Turbo Diesel, ShortBox Project WTF: 2007 Blue Suzuki Hayabusa - Shaved, Rear Links/Tree Spacers (Lowered 1.25"), VisionPro 6k High/Low HIDs, Tail Bag, Tobin Seat, Custom Cherry Bomb Exhaust |
<div> (babuski @ Oct. 04 2007,08:13)</div><div id="QUOTEHEAD">QUOTE</div><div id="QUOTE">how much are a new set of these cush components....?</div> I just replaced mine wednesday @ 49.9k. after taxes the set o' 6 cost barely under 50 bucks at the local stealership. difference is day and night! a lot smoother now. had to soap the new ones to get the hub on. listed on the ipb # 17 - shock asorbers ,on the rear wheel screen. |
| Thread Tools | |
| Display Modes | |
