I would think its more of a clutch issue. Clutch is dragging a little so you have to match revs. Not as noticable on upshifts since you naturally ease off the throttle.(VABUSA1 @ Sep. 06 2007,08:29) Will shift up fine, but very hard to shift down, unless you bump the throttle a little. Some people told me a bent shifter fork, but I think its the clutch?
Good question to try to isolate it!(JuiceSC @ Sep. 06 2007,11:15) Can you get into neutral easily AFTER you've come to a stop?
I've owned bikes for over 3 decades. And was a mech for 15 years.(Professor @ Sep. 06 2007,09:23)Good question to try to isolate it!(JuiceSC @ Sep. 06 2007,11:15) Can you get into neutral easily AFTER you've come to a stop?
[/Quote](heavybusa @ Sep. 06 2007,12:39) Is this a Michele's evil twin??
VABUSA1
no neutral is also hard to find, I use Mobil 1 cycle oil. Can the clutch be adjusted?(JuiceSC @ Sep. 06 2007,09:40)I've owned bikes for over 3 decades. And was a mech for 15 years.(Professor @ Sep. 06 2007,09:23)Good question to try to isolate it!(JuiceSC @ Sep. 06 2007,11:15) Can you get into neutral easily AFTER you've come to a stop?
mobil 1 oil, 8900 miles on the bike, hard to find neutral when completely stoped. Bike was stolen and left on its side overnight, when pulled up sat for about a minute and started, oil light took a while to go off.(VABUSA1 @ Sep. 06 2007,08:29) Will shift up fine, but very hard to shift down, unless you bump the throttle a little. Some people told me a bent shifter fork, but I think its the clutch?Iuse Mobil 1 cycle oil, its been about 1 year since changed but only about 300 miles. And neutral is hard to find if completely stoped.
right now the bike is at Champion Motorsports in Sterling getting the bodypanels replaced. They are supposed to check the clutch and trans out and give me a call.(GMbusa @ Sep. 07 2007,12:07) Vabusa1, i'm nearby up in Springfield,Va. Give me a ring. I'll be happy to look at or help you out with your Busa.
540-223-3785 Paul
Dont think the clutch is adjustable -- hydraulic(Big Red @ Sep. 07 2007,19:46) Eliminate one problem at a time with the easy stuff like clutch adjustment and go from there--- methinks it is the blinker fluid. Before you start spending money have someone who knows what the fark they are doing and check it if you are unsure of your own abilities.
