I've heard of better, like low 50's at highway speeds, but I don't know what speeds attained those results. I'm fairly certain that 6th was used, though. I'm of the belief that the Busa gets it's best economy significantly above the speed limit. Try 6th gear at 85-90 and see what that does. Personally, I would match the display to pump results, as it's possible that it's reporting better or worse than you are actually getting. If you've got anything affecting the odometer, such as sprocket changes or a different sized tire, that needs to be taken into account. And depending on the way an engine is tuned, it's efficiency can be all over the map, or not at all. Highly likely that the slight extra fuel added in 5th adds enough torque to overcome consumption in comparison to lower gears. ______________________________________
The Sovereign’s Charter of Liberties Imperium Carta Libertatum |
i have 16/42 gearing and if i hold around 4500 rpms in 6th gear i get between 48-51 mpg
2001 Hayabusa lowered 1 front, 2 rear, M4 exhaust, Ti header/ CF muffler & PCII, +6 Catalyst fiberglass tail, +6 swing arm, '99 Alum. Subframe, Alum. Triple Tree, C/F front fender / chain guard / inner panels / mirrors, AirTech Slammed fiberglass tank, Vortex -1 +2 sprockets, EK 530ZZZ gold chain, air shifter, PUIG smoke DB, BMC Race Filter, Galfer S/S lines, APE Clutch, APE HD springs, 1 piece clutch hub, Clear Clutch cover, APE cam chain tensioner, Shinko R003 120/70 & 200/50, next..cams |
I have 17/43 gearing and im mapped out 10% fat because of the NOS,I average btwn 25-30mpg...Im not real concerned with it,im just out for fun,if i was worried about fuel miliage id buy a geo metro for 55mpg * ______________________________________
08' BLACK/ORANGE 02' BLACK LE SOLD 08' FunkMasterFlex Expedition #373 |
Mine is stock and I usually see about 50mpg on the interstate and about 44-45 on surface roads. The most efficient speed seems to be running down the interstate about 80mph. ______________________________________
2001 Pantera 125 Dirt Bike, 2004 Yahama VSTAR 650, 2005 Hayabusa, 2005 Ninja 250, 2006 SV650, 2007 GSXR 750 ~ Don's Pictures ~ |
80 mph in 6th gets me 49.6 mpg. Below that or above 85 it starts to drop. If I put a 120 lb passenger on the back (which would bring me up to your 280 lbs) I could easily see it dropping to 44 mpg. I'd say your engine is at peak efficiency. Around town it's going to drop no matter what. One of my favorite things about the Busa is its great highway mileage for those 1000 to 2000 mile weekend road trips. If all I did was ride around town all day, I'd by a mountain bike. ______________________________________
George CX500 TURBO CX650 TURBO '04 Blue/Silver Hayabusa |
Hmmm. I have neve peaked higher than 41. But then again, never lower than 29. Still sounds like a good range to me.
Mods: Custom Paint (Cherry Red with Ghost Flames) Galfer Steel Braided Lines (Front, Rear, Clutch) EBC Pads TRE (because I want to put 220 gages on there) PCIII (Because I really don't know what the TRE does) K&N Filter Muzzy Fan Custom Built Straight Pipes (stock headers and mid-pipe) |
I am right in there with Dadofthreee, Rayabusa and Turbo-Torch. I find that if I drive very easy and shiftthrough at 2K or so I can stay at 42-4 in town. And about a steady 75 in 6th yields a 50-2, non tucked on cruise control. But if you ask it for power, it drops quickly. I can easily see it go to 29 in town and 36-8 on highway if I'm twisting the wrist agressively. I also noticed an improvement when I installed a PC III and loaded a stock map. BTW the bike is stock in the engine dept. ______________________________________
03 Copper 40th Anniversary Edition Kanji Mirror Mod Tobin Front & Rear Seats Puig Touring Screen In Dark Smoke Buell Peg Mod HEL Braided Stainless Lines EBC-HH pads Reaper Risers GI Pro PAIR Valve Sucker Mod Dual HIDs PC III USB...Running stock map. Mirror Extensions All black Pazzo's SpeedoHealer (I was 10% off) Lou's Custom Undertail |
Over the past 2XXX or so miles (havnt cleared the odometer in a LONG time lol. (29XX on the bike) I have adveraged over 45MPG. I rarely tuck in while riding BTW. I cleared it before and on the highway @ 70ish it pegged the reading @ 50MPG....I have also tested it at the pump vs miles and it came up with like 45-48 MPG. Stock gearing and all that...all I have are frame sliders and factory lowered rear..... and at that time it was totally stock. ______________________________________
2006 grey/blue Suzuki GSX1300R hayabusa (almost stock) * 2004 silver mustang GT~ VT cams~ Custom twin 57MM turbo setup~ 479RWHP/512RWTQ @ 9PSI~ 11.75 @ 122MPH 1966 emberglow mustang~ HEAVILY modified 331 stroker setup for a supercharger. * |
I have never tried to check when i have maximum efficiancy, but i notice it go down when i'm on the throttle alot, and go up when i'm smooth. However when driving normal it is always at 34mpg in town. Keep in mind it has 36K miles on it so i'm sure i'm losing a little there.
I have been very impressed with the mileage I get on the bus, 49-50 indicated and @ the pump 47-48 mpg average. This is 80%+ highway 75 to 85 indicated without a speedo healer on 87 octane. This was one of the largest reasons I got the bus instead of the zx-14. BTW my XX returned about 42mpg.
I just saw this thing on myth busters about drafting behind other vehicles. Even at a safe 2 to 3 second following rule behind another car, your vehicle can increase it's fuel efficiency by 10-12%. At a 1 second distance, it can increase by as much as 25-30%. So, if you're commuting all the time and always on the highway/interstate, I guess it does pay in the long run to follow behind someone. ______________________________________ ![]() 06 Blk/Grey Busa Sportech v-flow Black Trans Chrome windscreen Mudguard mod Hump Mod with Tiger Racing glovebox Steering Damper Mod (90W gear oil) All stickers and graffix removed except Kanji Vortex 42 tooth rear sprocket (black) EK VTX Chain Race Tech 1.1 Gold valve front forks |
<div> (Ninja Eater @ Jul. 11 2007,09:31)</div><div id="QUOTEHEAD">QUOTE</div><div id="QUOTE">Hmmm at 184mph and above I get about 12mpg and keeping the RPMs at 4500rmp out of 12,000rpm (modified) can get about 46mpg</div> ahahaha....12mpg...a hummer gets bettr miliage!! ______________________________________
| Thread Tools | |
| Display Modes | |
