2 stroke turbo engine (FI only)
IG.
I've been thinking... Tell me where I am going wrong.
You take a 4-stroke engine, and make the following changes.
o Change crank and cam ratio to 1:1 instead of 2:1, so for every revolution of the crank, the cams also turn once. Cams profiles have to be changed (new cams of course).
o Intake air is pressurized (5 - 10 psi).
o FI maps have to be re-adjusted.
o Ignition times have to be adjusted.
Here is how it "supposed" to work. Let's start from ignition at TDC, and go 360 deg till next ignition.
-30 - 0 deg: ignition (negative degree for advance)
100 deg: exhaust valve opens
140 deg: intake valve opens, compressed air purges exhaust gases
170 deg: exhaust valve closes
180 deg: intake valve closes
230 deg: fuel injected, compression continues
300 - 360 deg: next ignition
All degrees are to just illustrate the principle. Of course, extra cooling is a separate matter.
That would be a two stroke turbo. What do you think?
not sure where I saw it but have recently seen a 4 stroke using premix and no crankcase oil.
A 2 stroke cycle diesel engine uses almost exactly what you have described but diesel fuel & 22:1 compression w/ no spark plug.
Thanks, Mikey,
I did a quick search on Yahoo! and found this Diesel 2 stroke engine.
It could be a cool 2 stroke gasoline engine - supercharged, or turbocharged (assuming compression ratio is reduced, and fuel injectors are added), producing like 2.5 times more power than a 4 stroke with the same size cylinders.
Don't know about emissions though.
Correct, I forgot to mention the 2 stroke cycle diesel uses a supercharger, no intake valve and at least one exhaust valve.
With an exhaust valve the emissions should be no problem.  Put one thgether and I'll split the proceeds with you! :D  :beerchug:
<!--EDIT|Mikey D
Reason for Edit: "Cause I forgot"|1069361160 -->
Ha-ha-ha!
That would be a neat project.
But, I've never heard of modern car/motorcycle turbo/super-charged 2 strokes following this principle.
Perhaps there is no mass market for it.
I wonder if anything like this is used in racing.
I replied in the Turbo forum in detail, you should check it out.
<!--EDIT|Noltez
Reason for Edit: None given...|1069463473 -->
